Create invisible containers/objects
Custom ESP32 with SSD1306: Mono 64x48 landscape
7.5.0
I’d like to be able to divide my screen into sections and then center labels inside those sections of the screen.
I was able to achieve this with objects but it would be nice if there were no borders as my screen area is very limited.
// Get the current screen and wipe all child objects
lv_obj_t *scr = lv_scr_act();
lv_obj_clean(scr);
// Divide the screen in half
lv_obj_t *leftPlug = lv_obj_create(scr, NULL);
lv_obj_set_size(leftPlug, 32, 48);
lv_obj_t *rightPlug = lv_obj_create(scr, leftPlug);
lv_obj_set_pos(rightPlug, 32, 0);
// Create left plug symbols centered on the left side
// Check state and display result, use dummy values for now
lv_obj_t *leftTitle = lv_label_create(leftPlug, NULL);
lv_label_set_text(leftTitle, "L\n" LV_SYMBOL_BATTERY_1 LV_SYMBOL_CHARGE "\n" LV_SYMBOL_DOWNLOAD LV_SYMBOL_CLOSE);
lv_obj_align(leftTitle, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
// Create right plug symbols centered on the right side
lv_obj_t *rightTitle = lv_label_create(rightPlug, NULL);
lv_label_set_text(rightTitle, "R\n" LV_SYMBOL_CLOSE "\n");
lv_obj_align(rightTitle, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
It should be possible to do this by setting the bg_opa property of the objects’ styles to LV_OPA_TRANSP. You may have to do the same for border_opa as well.
you could used CONT to split the screen,and set the boder’s widght of style to 0
lv_obj_t* cont_topleft;
lv_obj_t* cont_bottomleft;
lv_obj_t* cont_topright;
lv_obj_t* cont_bottomright;
lv_obj_t* cont_table[] = { &cont_topleft ,&cont_topright ,&cont_bottomleft,&cont_bottomright };
uint8_t align_table[] = { LV_ALIGN_IN_TOP_LEFT ,LV_ALIGN_IN_TOP_RIGHT ,LV_ALIGN_IN_BOTTOM_LEFT ,LV_ALIGN_IN_BOTTOM_RIGHT };
void create_label_cente(lv_obj_t* parent)
lv_obj_t* txt_label = lv_label_create(parent, NULL);
lv_label_set_text(txt_label, "text");
lv_obj_align(txt_label, parent, LV_ALIGN_CENTER, 0, 0);
void screen_spit(void)
for (uint8_t i = 0; i < 4; i++)
cont_table[i] = lv_cont_create(lv_scr_act(), NULL);
/* lv_obj_set_style_local_border_width(cont_table[i],LV_OBJ_PART_MAIN,LV_STATE_DEFAULT,0);
lv_obj_set_style_local_bg_opa(cont_table[i], LV_OBJ_PART_MAIN, LV_STATE_DEFAULT,0);*/
lv_obj_set_size(cont_table[i], 100, 100);
lv_obj_align(cont_table[i], NULL, align_table[i], 0, 0);
create_label_cente(cont_table[i]);
Maybe I’m not understanding something here: why initialize cont_table with references to the global pointers, just to overwrite them?
Because the argument is passed as a pointer, another easy way to understand it is to use structures, such as
typedef struct
const void* src_img;
}img_table_t;
img_table_t img_table[]={&main_page,&menu,¬ebinding,¬eduty,&hardwarecheck,&examready,&examing,&examend};
lv_img_set_src(main_png,im_tbale[0]);
