I have created an extensive GUI so far using the awesome LVGL and now wish to add several .bmp images. The images are held on a microSd card. I am using a 320 x 480 display with capacitive touchscreen and a Teensy 4.0 processor. The microSd card reader is hardwired to the Teensy SDIO pins on the underside of the board. Libraries can be seen in the code included. The example image file on the sd card is taken from the LVGL examples for 16bit.
Arduino IDE 1.8.13
Teensyduino 1.8.5
LVGL 8.1
I would like to display images. The display currently is just white… although see below…
Are there some tips to check if I have the conf.h correct?
The sd card is formatted FAT32 . Is this OK?
I am not sure the file path for Arduino is OK when trying to use LVGL files when ‘S’ is selected…some guidance would help?
Many thanks for any assistance.
I have looked at a number of other examples and tried to recreate the code used. I have read the LVGL info for 8.1 images and file systems. I can only find a few examples using Teensy and the code I have used is based on these.
I have included the conf.h . #define LV_USE_BMP 1. #define LV_USE_FS_STDIO ‘S’
#define LV_FS_STDIO_PATH “/home/john/” /*Set the working directory… I am unsure whether I need to put a path here… an indication would be appreciated.
If I leave #define LV_USE_FS_STDIO as’\0’ the code will compile but no image is displayed. If I define ‘S’ in conf.h I get error message…
/*Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Teensy 4.0 Flash, Serial, 150 MHz, Faster, US English"
In file included from c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\dirent.h:7:0,
from C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:15:
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\sys\dirent.h:10:2: error: #error "<dirent.h> not supported"
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c: In function 'fs_dir_open':
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:213:12: warning: implicit declaration of function 'opendir' [-Wimplicit-function-declaration]
return opendir(path);
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:213:12: warning: return makes pointer from integer without a cast [-Wint-conversion]
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c: In function 'fs_dir_read':
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:261:17: warning: implicit declaration of function 'readdir' [-Wimplicit-function-declaration]
entry = readdir(dir_p);
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:261:15: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:263:21: error: dereferencing pointer to incomplete type 'struct dirent'
if(entry->d_type == DT_DIR) sprintf(fn, "/%s", entry->d_name);
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:263:33: error: 'DT_DIR' undeclared (first use in this function)
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:263:33: note: each undeclared identifier is reported only once for each function it appears in
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c: In function 'fs_dir_close':
C:\Users\Andy\Documents\Arduino\libraries\lvgl-release-v8.1\src\extra\libs\fsdrv\lv_fs_stdio.c:303:5: warning: implicit declaration of function 'closedir' [-Wimplicit-function-declaration]
closedir(dir_p);
Error compiling for board Teensy 4.0 Flash.
Unable to open COM7*/
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
/*#include <HX8357_t3n.h> // Hardware-specific library
#include <SPI.h>
#include "SdFat.h"
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins. For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define TFT_DC 20
#define TFT_CS 10
#define TFT_RST 14
#include <Arduino.h>
#include <lvgl.h>
//#include "lv_bmp.h"
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
HX8357_t3n tft = HX8357_t3n(TFT_CS, TFT_DC, TFT_RST);
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
const uint8_t SD_CS_PIN = SS;
// Try to select the best SD card configuration.
#define SD_CONFIG SdioConfig(FIFO_SDIO)
SdFs sd;
static const uint32_t screenWidth = 320;
static const uint32_t screenHeight = 480;
static lv_color_t buf[screenWidth * 10];
lv_disp_t *disp;
uint32_t timeNow = 0; // for timing in main loop
Notes:
* Must declare objects before using them!
* Must only initialise once
* Set style then position
void my_log_cb(const char *buf)
// Serial.printf(buf, strlen(buf));
// Display flushing
lv_disp_flush_ready(disp);
tft.writeRect(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1), (uint16_t *)color_p);
/* tell lvgl that flushing is done */
//SD Card Functions:
static bool sd_ready_cb(lv_fs_drv_t *drv)
Serial.println("Asked if drive ready!");
return 1;
//needs real code here...
* Open a file
* @param drv pointer to a driver where this function belongs
* @param path path to the file beginning with the driver letter (e.g. S:/folder/file.txt)
* @param mode read: FS_MODE_RD, write: FS_MODE_WR, both: FS_MODE_RD | FS_MODE_WR
* @return a file descriptor or NULL on error
static void *sd_open_cb(lv_fs_drv_t *drv, const char *path, lv_fs_mode_t mode)
//File *fp = (File *)lv_mem_alloc(sizeof(File));
File *fp = new (File); // when opening file
if (fp == NULL)
return NULL;
File mySDfile = *fp;
/*Make the path relative to the current directory (the projects root folder)*/
char buf[256];
sprintf(buf, "/%s", path);
if (mode == LV_FS_MODE_WR)
/*Open a file for write*/
mySDfile = sd.open(buf, O_WRONLY);
// mySDfile = SD.open(buf, O_WRONLY);
else if (mode == LV_FS_MODE_RD)
/*Open a file for read*/
mySDfile = sd.open(buf, O_RDONLY);
else if (mode == (LV_FS_MODE_WR | LV_FS_MODE_RD))
/*Open a file for read and write*/
mySDfile = sd.open(buf, O_RDWR);
//make sure at the beginning
mySDfile.seek(0);
*fp = mySDfile;
return fp;
* Close an opened file
* @param file_p pointer to a file_t variable. (opened with fs_open)
* @return LV_FS_RES_OK: no error or any error from @lv_fs_res_t enum
static lv_fs_res_t sd_close_cb(lv_fs_drv_t *drv, void *file_p)
File *fp = (File *)file_p; /*Just avoid the confusing casings*/
fp->close();
// delete (fp); // when close
return LV_FS_RES_OK;
* Read data from an opened file
* @param buf pointer to a memory block where to store the read data
* @param btr number of Bytes To Read
* @param br the real number of read bytes (Byte Read)
static lv_fs_res_t sd_read_cb(lv_fs_drv_t *drv, void *file_p, void *fileBuf, uint32_t btr, uint32_t *br)
//Serial.println("Call Back Asked to read file");
File fileSD = *fp;
// Serial.println((int)fileSD.available());
*br = fileSD.read(fileBuf, btr);
lv_fs_res_t res = LV_FS_RES_OK;
return res;
* Set the read write pointer. Also expand the file size if necessary.
* @param file_p pointer to a file_t variable. (opened with fs_open )
* @param pos the new position of read write pointer
* @param whence tells from where to interpret the `pos`. See @lv_fs_whence_t
static lv_fs_res_t sd_seek_cb(lv_fs_drv_t *drv, void *file_p, uint32_t pos, lv_fs_whence_t whence)
//FsFile *fp = (FsFile *)file_p; /*Just avoid the confusing casings*/
if (whence == LV_FS_SEEK_SET)
// fp->seek(pos, 0);
fp->seek(0);
// Serial.println("whence seek 0");
if (whence == LV_FS_SEEK_CUR)
// fp->seek(pos, 1);
fp->seek(1);
if (whence == LV_FS_SEEK_END)
// fp->seek(pos, 2);
fp->seek(2);
return res;
* Give the position of the read write pointer
* @param pos_p pointer to to store the result
static lv_fs_res_t sd_tell_cb(lv_fs_drv_t *drv, void *file_p, uint32_t *pos_p)
*pos_p = fp->position();
void lv_bmpLogo(void)
lv_obj_t *img = lv_img_create(lv_disp_get_scr_act(NULL));
// lv_img_set_src(img, "S:SeelyHole1.bin");
// lv_img_set_src(img, "S:blue_flower_16.bin");
lv_img_set_src(img, "S:example_16bit.bmp");
lv_obj_center(img);
void setup()
if (!sd.begin(SdioConfig(FIFO_SDIO))) {
Serial.println(F("SD card begin failed"));
Serial.println("SD card begin OK!");
Serial.begin(115200);
//Init LVGL and TFT:
//lv_log_register_print_cb(my_log_cb);
// lv_bmp_init();
tft.begin();
tft.invertDisplay(1);// had to add this line as without the original code shows the colors inverted
tft.setRotation(0);
delay(100);
tft.fillScreen(HX8357_BLUE);
lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * 10);
//Initialize the display
lv_disp_drv_init(&disp_drv);
disp = lv_disp_drv_register(&disp_drv); /*Register the driver and save the created display objects*/
Serial.println("I got to the initing file sys!");
//setup LVGL File System:
static lv_fs_drv_t drv; //Needs to be static or global
lv_fs_drv_init(&drv); /*Basic initialization*/
drv.letter = 'S'; /*An uppercase letter to identify the drive */
// drv.cache_size = sd_cache_size;
// drv.file_size = sizeof(File);
// drv.file_size = sizeof(File*);
drv.ready_cb = sd_ready_cb; /*Callback to tell if the drive is ready to use */
drv.open_cb = sd_open_cb; /*Callback to open a file */
drv.close_cb = sd_close_cb; /*Callback to close a file */
drv.read_cb = sd_read_cb; /*Callback to read a file */
drv.write_cb = NULL; /*Callback to write a file */
drv.seek_cb = sd_seek_cb; /*Callback to seek in a file (Move cursor) */
drv.tell_cb = sd_tell_cb; /*Callback to tell the cursor position */
drv.dir_open_cb = NULL; /*Callback to open directory to read its content */
drv.dir_read_cb = NULL; /*Callback to read a directory's content */
drv.dir_close_cb = NULL; /*Callback to close a directory */
//drv.user_data = my_user_data; //Any custom data if required
lv_fs_drv_register(&drv); /*Finally register the drive*/
Serial.println("I registered drv!");
void openCloseFile()
//Testing LV file open method:
lv_fs_file_t fileSD;
lv_fs_res_t res;
// res = lv_fs_open(&fileSD, "S:SeelyHole1.bin", LV_FS_MODE_RD);
// res = lv_fs_open(&fileSD, "S:blue_flower_16.bin", LV_FS_MODE_RD);
res = lv_fs_open(&fileSD, "S:example_16bit.bmp", LV_FS_MODE_RD);
if (res != LV_FS_RES_OK)
Serial.println("LV Failed to open SD File!");
Serial.println("LV Opened SD File!");
uint32_t read_num;
uint32_t charTOread = 8;
uint8_t newFileBuf[8];
res = lv_fs_read(&fileSD, newFileBuf, charTOread, &read_num);
Serial.println("LV did a SD File Read!");
for (int a = 0; a < 8; a++)
// Serial.print((char)newFileBuf[a]);
// Serial.print(" ");
Serial.println("");
res = LV_FS_RES_OK;
Serial.println("LV Couldn't Read!");
Serial.println("LV Read DATA!");
Serial.print("LV File Pointer before close: ");
Serial.println((int)&fileSD);
lv_fs_close(&fileSD);
Serial.print("LV File Pointer after close: ");
Serial.println("closed file");
void loop()
delay(5);
if (millis() > timeNow + 3000)
timeNow = millis();
// openCloseFile(); // for testing opening a file multiple times
lv_bmpLogo(); // for testing opening and closing a BMP image multiple times
With no ‘S’ in the conf.h, the function…
// lv_img_set_src(img, “S:SeelyHole1.bin”);
// lv_img_set_src(img, “S:blue_flower_16.bin”);
lv_img_set_src(img, “S:example_16bit.bmp”);
lv_obj_center(img);
… will display a 100 x 100 (correct size) image as per photo…
and the function…
openCloseFile();
… just has white screen
