I tried to use the 32 bit image in LVGL, but i’m unable to show this type of image.
latest
I want to show a 32 bit image on my display.
I have created a bmp image using paint. I have saved the image as 24 bit bmp and after, using LVGL image converter, I create a C array using the true color chroma key option. The lv_conf is configured as you see in the next section.
However the image that my display show are different from the original.
I miss something?
/* Color depth:
* - 1: 1 byte per pixel
* - 8: RGB233
* - 16: RGB565
* - 32: ARGB8888
#define LV_COLOR_DEPTH 32
/* Swap the 2 bytes of RGB565 color.
* Useful if the display has a 8 bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/* 1: Enable screen transparency.
* Useful for OSD or other overlapping GUIs.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's style should be modified: `style.body.opa = ...`*/
#define LV_COLOR_SCREEN_TRANSP 1
