Crash while rendering Freetype font
This code work fine with normal font. But when I use Freetype to load and render font, it crashes when lv_timer_handler() in loop() is called. The cause is from LittleFS read from the font file. Somehow the font is loaded aleady.
Here’s the
#include <LovyanGFX.hpp>
#include "finalFrontier.h"
 #include "ft2build.h"
#include <LittleFS.h>
#include "lfs.h"
#include <Ticker.h>
#include "esp_log.h"
#include <stdio.h>
#include "esp_err.h"
#include FT_FREETYPE_H
#define LV_USE_FREETYPE 1
#define LV_USE_LOG            1
#define LV_LOG_LEVEL          LV_LOG_LEVEL_WARN
#include <lvgl.h>
#include <ft2build.h>
#include "esp_littlefs.h"
static LGFX lcd;
static lv_draw_buf_t *draw_buf;  // Changed from lv_disp_draw_buf_t
static lv_color_t *lv_disp_buf;
static lv_disp_t *disp;
static lv_color_t *buf1;
static lv_color_t *buf2;
LGFX gfx;
// ========== LVGL Display Callbacks (LVGL 9.3 style) ==========
void my_flush_cb(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) {
  gfx.startWrite();
  gfx.setAddrWindow(area->x1, area->y1, area->x2 - area->x1 + 1, area->y2 - area->y1 + 1);
  gfx.pushImageDMA(area->x1, area->y1, area->x2 - area->x1 + 1, area->y2 - area->y1 + 1, (uint16_t *)px_map);
  gfx.endWrite();
  lv_display_flush_ready(disp);
Ticker lvgl_tick;
static uint32_t my_tick(void)
    return millis();
// ========== Setup ==========
void setup() {
  Serial.begin(115200);
esp_vfs_littlefs_conf_t conf = {
    .base_path = "/littlefs",
    .partition_label = "spiffs",
    .format_if_mount_failed = true,
    .dont_mount = false
esp_err_t ret = esp_vfs_littlefs_register(&conf);
if (ret != ESP_OK) {
    ESP_LOGE("TAG", "Failed to mount LittleFS");
    return;
  gfx.init();
  lv_freetype_init(256);
  lv_font_t * font = lv_freetype_font_create("/littlefs/Final-Frontier.ttf",
                                                     LV_FREETYPE_FONT_RENDER_MODE_BITMAP,
                                                     12,
                                                      LV_FREETYPE_FONT_STYLE_NORMAL);
    if(!font) {
        LV_LOG_ERROR("freetype font create failed.");
        return;
  static lv_color_t *buf1 = (lv_color_t *)heap_caps_malloc(240 * 10 * sizeof(lv_color_t), MALLOC_CAP_DMA);
  lv_display_t *disp = lv_display_create(240, 320);
  lv_display_set_flush_cb(disp, my_flush_cb);
  lv_display_set_buffers(disp, buf1, NULL, 240 * 10, LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_tick_set_cb(my_tick);
   static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, font);
    lv_style_set_text_align(&style, LV_TEXT_ALIGN_CENTER);
  lv_obj_t *label = lv_label_create(lv_screen_active());
  lv_label_set_text(label, "Hello");
  lv_obj_center(label);
void loop() {
  lv_timer_handler();  // Process GUI events
  delay(100);
My lv_conf.h
`#ifndef LV_CONF_H
#define LV_CONF_H
LVGL CONFIGURATION
/* Enable selected parts of LVGL */
#define LV_USE_DRAW_BUF 1
#define LV_USE_LABEL 1
//#define LV_USE_FS_LITTLEFS 1
//#define LV_FS_LITTLEFS_LETTER ‘C’
#define LV_USE_FS_ARDUINO_ESP_LITTLEFS 1
#define LV_FS_ARDUINO_ESP_LITTLEFS_LETTER ‘C’
/* Enable logging (optional for debugging) */
/* FreeType font settings /
#define LV_FREETYPE_CACHE_SIZE (32 * 1024)
//#define LV_FREETYPE_CACHE_SIZE 256 /
Set to 0 to disable cache /
#define LV_USE_OS LV_OS_NONE /
For ESP32, we disable OS support */
#define LV_FONT_MONTSERRAT_16 1 /* You can disable if using only FreeType */
/* Memory settings (tweak as needed) /
#define LV_MEM_SIZE (48 * 1024) /
48KB of memory for LVGL /
Tick period (ms) - depends on your system timer */
#define LV_TICK_PERIOD_MS 1
/* Default DPI for fonts (used by FreeType if applicable) */
#define LV_DPI_DEF 130
#endif /LV_CONF_H/``
type or paste code here
An update. This same code and config work fine when I switch to espidf. it crashes with arduino only
