I created a file selector, but while it’s scrolling down and I select one, crash.
ESP32-WROVER
v7.5.0
ESP IDF v5
DIR* dir = opendir("/S/");
if (dir == NULL) {
return;
lv_obj_t *file_list = lv_list_create(scrHistory, NULL);
lv_obj_set_size(file_list, DISP_RES_X, DISP_RES_Y/1.3);
lv_obj_set_pos(file_list, 0, 0);
while (true) {
struct dirent* de = readdir(dir);
if (!de) {
break;
if(strstr(de->d_name, "_meres.txt")){
printf("Found file: %s\n", de->d_name);
lv_obj_t *btn = lv_list_add_btn(file_list, LV_SYMBOL_FILE, de->d_name);
lv_obj_set_event_cb(btn, event_handler_list);
closedir(dir);
lv_obj_t * labelbtn;
exitBtn = lv_btn_create(scrHistory, NULL);
lv_obj_align(exitBtn, NULL, LV_ALIGN_CENTER, +DISP_RES_X/3, +DISP_RES_Y/3);
lv_obj_set_size(exitBtn, DISP_RES_X/4.3, DISP_RES_Y/7);
labelbtn = lv_label_create(exitBtn, NULL);
lv_label_set_text(labelbtn, "Exit");
lv_obj_set_event_cb( exitBtn , event_handler_exit);
lv_scr_load(scrHistory);
event handler:
static void event_handler_list(lv_obj_t * obj, lv_event_t event)
ESP_LOGI("list handler", "%s", lv_list_get_btn_text(obj));
readFile(lv_list_get_btn_text(obj));
crash info:
Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero). Exception was unhandled.
Core 1 register dump:
PC : 0x400f781d PS : 0x00060030 A0 : 0x800f7a55 A1 : 0x3ffc1dd0
0x400f781d: draw_series_line at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_widgets/lv_chart.c:984
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x3ffb466c A5 : 0x3ffb46d4
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x3ffc1db0
A10 : 0x3ffb46d4 A11 : 0x00000002 A12 : 0x00000003 A13 : 0x3ffb468c
A14 : 0x00000003 A15 : 0x00000002 SAR : 0x00000001 EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000
Backtrace: 0x400f781a:0x3ffc1dd0 0x400f7a52:0x3ffc1f50 0x400e4f62:0x3ffc1fd0 0x400e4fc7:0x3ffc2020 0x400e5001:0x3ffc2070 0x400e52f0:0x3ffc2090 0x400e5475:0x3ffc2120 0x400e555c:0x3ffc2150 0x400e55c4:0x3ffc2170 0x400eee91:0x3ffc21a0 0x400eef7c:0x3ffc21c0 0x400d7488:0x3ffc21e0 0x4008a771:0x3ffc2250
0x400f781a: draw_series_line at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_widgets/lv_chart.c:984
0x400f7a52: lv_chart_design at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_widgets/lv_chart.c:754 (discriminator 1)
0x400e4f62: lv_refr_obj at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:677 (discriminator 1)
0x400e4fc7: lv_refr_obj at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:717
0x400e5001: lv_refr_obj_and_children at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:619
0x400e52f0: lv_refr_area_part at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:550
0x400e5475: lv_refr_area at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:460 (discriminator 2)
0x400e555c: lv_refr_areas at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:382
0x400e55c4: _lv_disp_refr_task at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_core/lv_refr.c:199
0x400eee91: lv_task_exec at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_misc/lv_task.c:409 (discriminator 1)
0x400eef7c: lv_task_handler at /home/molnarm/esp-workspace/project/components/lv_port_esp32/components/lvgl/lvgl/src/lv_misc/lv_task.c:142
0x400d7488: menuTask at /home/molnarm/esp-workspace/project/main/guiTask.c:110
0x4008a771: vPortTaskWrapper at /home/molnarm/esp-idf/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:154
