I have enabled the:
LV_USE_PERF_MONITOR 1
LV_USE_MEM_MONITOR 1
When I run an example like the “lv_example_anim_3()” without the debug information the image displayed fine, but when I use debug window the debug window is corrupted.
I’m using STM32 h7.
I’m trying to see the debug window without corruption.
I don’t really know where the problem comes from.
Code
void ili9488_flush_cb(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
//Set the drawing region
LCD_SetPos(area->x1, area->x2, area->y1, area->y2);
int height = lv_area_get_height(area);
int width = lv_area_get_width(area);
HAL_DMA2D_Start(&hdma2d, (uint32_t) color_p,
(uint32_t) (0x60000000 | 0x0200000), width, height);
HAL_DMA2D_PollForTransfer(&hdma2d, HAL_MAX_DELAY);
lv_disp_flush_ready(disp);
void my_clean_dcache_cb(lv_disp_drv_t *disp_drv) {
/* Example for Cortex-M (CMSIS) */
SCB_CleanInvalidateDCache();
Hi, I run the benchmark and it completes with graphical issues. I’m trying to follow and adjust to this example: STM32F769I-DISCO-LVGL/master.cpp at master · tdjastrzebski/STM32F769I-DISCO-LVGL · GitHub
to my STM32 H7 with no luck.
Interesting case - It works great when I use regular DMA or “Regular” transfers individually.
Interesting case - I saw when I send the picture or some pixel data that is static the output to display is not distorted but in some other cases it is distorted.
I don’t think I can help you much as I have no idea of how STM32 DMA2D works,
however I think this line is the issue:
I suspect the third argument is the start address for DMA? In my project I was writing directly to a framebuffer in DMA so I had to set the start address of DMA to the x/y positions of the area to be drawn.
However, it seems you already set the drawing position with LCD_SetPos… so I’m not sure.
My last hint is that you would have to figure out if there are functional differences between DMA2D on your MCU (STM32 H7) and the STM32F7-xxx, considering the other drawing functions have no graphical issues.
