Hi, I want to draw a line. The code likes below, I know I could using the lv_line widget to do that. But what I want is to test if lv_draw_line works well. In some of case, I see the lv_draw_line() are in the event callback function, I want to using it not in the callback funciton. would it be works?
Thanks for your kindly help!
simulator
V8.0
draw a line using lv_draw_line() not in the callback function
search in forum
lv_obj_t * black_bg = lv_obj_create(m_lvObj);
//lv_obj_remove_style_all(black_bg);
lv_obj_set_size(black_bg, black_bg_w, black_bg_h);
lv_obj_set_pos(black_bg, 5, y_offset);
lv_obj_set_style_bg_color(black_bg, lv_color_hex(0x000000), 0);
lv_obj_set_style_bg_opa(black_bg, LV_OPA_COVER, 0);
lv_obj_refr_size(black_bg);
//lv_obj_invalidate(black_bg);
lv_draw_line_dsc_t line_dsc_default;
lv_draw_line_dsc_init(&line_dsc_default);
lv_obj_init_draw_line_dsc(black_bg, LV_PART_MAIN, &line_dsc_default);
// //first line
lv_area_t com_area = black_bg->coords;
lv_point_t p1;
lv_point_t p2;
p1.x = com_area.x1 + 0;
p1.y = com_area.y1 + 30;
p2.x = p1.x + lv_area_get_width(&com_area);
p2.y = p1.y ;
//line_dsc_default.color.full = 0x0000FF00;
line_dsc_default.color = lv_color_hex(0xAFB5BF);
line_dsc_default.width = 20;
lv_draw_line(&p1, &p2, &com_area, &line_dsc_default);
