I am pretty new to LVGL. This is start of my first project.
I am able to get x and y coordinates through lv_port_indev.c.
I am able to make a sample GUI and define its callback.
When I press the screen, I am able to get the touch coordinates in lv_port_indev but I do not get any button callback.
Do I have to manually map the touch input coordinates to button and manually define callbacks? I can not get callbacks automatically.
ARM
v7
I have touch coordinates but I do not get button callback. Pleae guide how to map these cooridnates to callback or I am thinking in wrong direction. There is a different approach?
I am planning to define button maps and manually check where the touch input coordinates are and then make manual callback.
Get coordinates
static bool touchpad_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
static lv_coord_t last_x = 0;
static lv_coord_t last_y = 0;
int screen_id = ((struct disp_data*)(indev_drv->disp->driver.user_data))->sdm->handle->display_id;
/Save the pressed coordinates and the state/
if(touchpad_is_pressed(screen_id)) {
touchpad_get_xy(&last_x, &last_y, screen_id);
>>>>>>> printf("%d %d \n", last_x, last_y);
} else {
data->point.x = last_x;
data->point.y = last_y;
/*Return `false` because we are not buffering and no more data to read*/
return false;
CREATE BUTTON
static void content_create(lv_obj_t * parent)
show_bg(parent, PNG_RES_PATH("img_background"));
printf("Hello World 123456789");
FL_TemperaturePlus_btn = lv_imgbtn_create(lv_scr_act(),NULL);
lv_obj_set_event_cb(FL_TemperaturePlus_btn, imgbtn_event_handler);
lv_imgbtn_set_src(FL_TemperaturePlus_btn,LV_STATE_DEFAULT,PNG_RES_PATH("FL_TemperaturePlus"));
lv_imgbtn_set_src(FL_TemperaturePlus_btn,LV_STATE_PRESSED,PNG_RES_PATH("FL_TemperaturePlusPressed"));
lv_obj_set_pos(FL_TemperaturePlus_btn,60,128);
DEFINED CALLBACK
static void imgbtn_event_handler(lv_obj_t *obj, lv_event_t e)
printf("I AM IN imgbtn_event_handler \n");
if(e == LV_EVENT_CLICKED) {
if(obj == FL_TemperaturePlus_btn) {
printf("--imgbtn_event_handler---click FL_TemperaturePlus_btn\n");
## Screenshot and/or video
May be not required.
