Convert image to C array automatically on code
  How to convert an image (JPEG || PNG || BMP || RAWRGB) to C array, specially to RGB565 (Color depth 16 bits) and fit it on Uint8_t to automatically create an image using lv_img_dsc_t?
  RP2040 MCU Board, With 1.28inch Round LCD
 8.3.6
Pass an image via bluetooth, convert it to Uint8_t ( only need "#if LV_COLOR_DEPTH == 16 && LV_COLOR_16_SWAP == 0
/Pixel format: Red: 5 bit, Green: 6 bit, Blue: 5 bit" part) that fits on lv_img_dsc_t data
 I've tried to replicate convert.ts provided on github but i did not understand it, but like, now i'm kinda thinking to send a image like jpeg, save the file and then use the JPG decoder.
void processReceivedImage(const uint8_t *decodedImageData){
  lv_img_dsc_t my_img_dsc = {
    .header.always_zero = 0,
    .header.w = 240,
    .header.h = 240,
    .data_size = 240 * 240 * LV_COLOR_DEPTH / 8,
    .header.cf = LV_IMG_CF_TRUE_COLOR,          /*Set the color format*/
    .data = decodedImageData,
  lv_img_set_src(ui_Image2, &my_img_dsc);
I would recommend converting your image to RGB565 binary before sending it, that way you don’t need to decode the image format to binary.
The other way would be using the image decoders available on LVGL, eg png, jpg then save the image to a file system and load it directly
