PIC32MZ
8.3
I want to control the lv_keyboard widget by sending it events. I am doing it like this:
KeyBoard = lv_keyboard_create(Screen);
int key = LV_KEY_RIGHT;
lv_event_send(KeyBoard, LV_EVENT_KEY, &key);
I expect to see the selected button move on the widget, but this does not happen.
How can I control the lv_keyboard widget using lv_event_send?
Thank you in advance for your help!
I have partially solved the problem. Before sending
I also need to send
lv_event_send(KeyBoard, LV_EVENT_FOCUSED, 0);
Now, by sending LV_KEY_RIGHT/LEFT/UP/DOWN, I can navigate between the buttons.
However, when I send LV_KEY_ENTER, the input is not added to the textarea, even though I have already linked it using
lv_keyboard_set_textarea(KeyBoard, TextArea);
Can someone help me with this?
I found a complete solution. You need to instead of the correct code LV_KEY_ENTER send lv_event_send(KeyBoard, LV_EVENT_PRESSED, 0);
thank you!
You help me a lot
