ESP 32-S3 / Screen is 3.5”480x320 TFT LCD Capacitive Touchscreen Breakout Wiki - DFRobot
with mfrc522
[env:esp32dev]
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
monitor_speed = 9600
lib_deps =
lvgl/lvgl@^8.3.4
lovyan03/LovyanGFX@^1.1.5
miguelbalboa/MFRC522@^1.4.10
bblanchon/ArduinoJson@^6.21.2
SPI
Wire
8.3.4
I’m trying to use the reader and screen at the same time
Both are working but it seems that when i use the reader, the screen goes off due to data being sent at the same time ?
I tried setting a timer / boolean but the result is the same when i scan a tag, the screen shut down.
Any idea ?
static void display_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
#ifdef DISABLE_FLUSH_DURING_BENCHMARK
if (disable_flush) {
lv_disp_flush_ready(disp);
return;
if (spiState) {
Serial.println("Calling display flush");
display.startWrite();
display.setAddrWindow(area->x1, area->y1, w, h);
display.writePixels((uint16_t *)&color_p->full, w * h, true);
display.endWrite();
static void touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) {
uint16_t touchX, touchY;
bool touched = display.getTouch(&touchX, &touchY);
if (!touched) {
} else {
data->point.x = touchX;
data->point.y = touchY;
static void lv_tick_task(void *arg) {
(void)arg;
lv_tick_inc(LV_TICK_PERIOD_MS);
static void radio_event_handler(lv_event_t * e)
uint32_t * active_id = (uint32_t*)lv_event_get_user_data(e);
lv_obj_t * cont = lv_event_get_current_target(e);
lv_obj_t * act_cb = lv_event_get_target(e);
lv_obj_t * old_cb = lv_obj_get_child(cont, *active_id);
/*Do nothing if the container was clicked*/
if(act_cb == cont) return;
lv_obj_clear_state(old_cb, LV_STATE_CHECKED);
lv_obj_add_state(act_cb, LV_STATE_CHECKED);
*active_id = lv_obj_get_index(act_cb);
LV_LOG_USER("Selected radio buttons: %d, %d", (int)active_index_1, (int)active_index_2);
static void radiobutton_create(lv_obj_t * parent, const char * txt)
lv_obj_t * obj = lv_checkbox_create(parent);
lv_checkbox_set_text(obj, txt);
lv_obj_add_flag(obj, LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_add_style(obj, &style_radio, LV_PART_INDICATOR);
lv_obj_add_style(obj, &style_radio_chk, LV_PART_INDICATOR | LV_STATE_CHECKED);
* Checkboxes as radio buttons
void checkbox_state(void)
lv_style_init(&style_radio);
lv_style_set_radius(&style_radio, LV_RADIUS_CIRCLE);
lv_style_init(&style_radio_chk);
lv_style_set_bg_img_src(&style_radio_chk, NULL);
uint32_t i;
char buf[32];
lv_obj_t * cont1 = lv_obj_create(lv_scr_act());
lv_obj_set_flex_flow(cont1, LV_FLEX_FLOW_COLUMN);
lv_obj_set_size(cont1, lv_pct(40), lv_pct(80));
lv_obj_align(cont1, LV_ALIGN_CENTER, 70, 0);
lv_obj_add_event_cb(cont1, radio_event_handler, LV_EVENT_CLICKED, &active_index_1);
lv_snprintf(buf, sizeof(buf), "%s", "Entree");
radiobutton_create(cont1, buf);
lv_snprintf(buf, sizeof(buf), "%s", "Sortie");
/*for (i = 0;i < 5;i++) {
lv_snprintf(buf, sizeof(buf), "A %d", (int)i + 1);
/*Make the first checkbox checked*/
lv_obj_add_state(lv_obj_get_child(cont1, 0), LV_STATE_CHECKED);
void initLvglLgfx() {
display.begin();
#ifdef LANDSCAPE
display.setRotation( 1 );
display.setBrightness(255);
#ifdef LV_DOUBLE_BUFFER
lv_disp_draw_buf_init(&draw_buf, buf, buf2, screenWidth * LV_BUFFER_SIZE);
#else
lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * LV_BUFFER_SIZE * 2);
disp_drv.flush_cb = display_flush;
lv_disp_drv_register( &disp_drv );
// Input device driver
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
// periodic timer interrupt
const esp_timer_create_args_t periodic_timer_args = {
.callback = &lv_tick_task, .name = "periodic_gui"
esp_timer_handle_t periodic_timer;
ESP_ERROR_CHECK(esp_timer_create(&periodic_timer_args, &periodic_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer, LV_TICK_PERIOD_MS * 1000));
/// OBJSSS
//calendar();
//anim_bar();
checkbox_state();
byte nuidPICC[4];
void printHex(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
void printDec(byte *buffer, byte bufferSize) {
Serial.print(buffer[i], DEC);
void playSound() {
//tone(BUZZZER_PIN, NOTE_E5, 16);
//delay(16);
//noTone(BUZZZER_PIN);
ledcWriteTone(7, 1000);
delay(500);
ledcWriteTone(7, 0);
void initBuzzer() {
ledcSetup(7, 1000, BUZZZER_PIN);
ledcAttachPin(BUZZZER_PIN, 7);
void rfidCheck() {
if ( ! rfid.PICC_IsNewCardPresent())
return;
// Verify if the NUID has been readed
if ( ! rfid.PICC_ReadCardSerial())
return;
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
Serial.println(rfid.PICC_GetTypeName(piccType));
if (rfid.uid.uidByte[0] != nuidPICC[0] ||
rfid.uid.uidByte[1] != nuidPICC[1] ||
rfid.uid.uidByte[2] != nuidPICC[2] ||
rfid.uid.uidByte[3] != nuidPICC[3] ) {
Serial.println(F("A new card has been detected."));
// Store NUID into nuidPICC array
for (byte i = 0; i < 4; i++) {
nuidPICC[i] = rfid.uid.uidByte[i];
Serial.println(F("The NUID tag is:"));
Serial.print(F("In hex: "));
printHex(rfid.uid.uidByte, rfid.uid.size);
Serial.println();
Serial.print(F("In dec: "));
printDec(rfid.uid.uidByte, rfid.uid.size);
Serial.println();
playSound();
else Serial.println(F("Card read previously."));
rfid.PICC_HaltA();
rfid.PCD_StopCrypto1();
void initRfid() {
// SPI.begin(12, 13, 11, 5);
rfid.PCD_Init();
rfid.PCD_WriteRegister(rfid.RFCfgReg, (0x07<<4));
rfid.PCD_AntennaOn();
delay(4);
rfid.PCD_DumpVersionToSerial();
Serial.println("RFID Initialized");
void setup() {
Serial.begin(115200);
// INIT LGFX
initLvglLgfx();
initRfid();
ESP_LOGI(TAG, "Ready to start a demo. Tap a button on screen. Reset the board with the reset button or Ctrl+T Ctrl+R to pick a new one.");
void loop()
lv_timer_handler();
vTaskDelay(pdMS_TO_TICKS(TASK_SLEEP_PERIOD_MS));
unsigned long currentMillis = millis();
unsigned long elapsedMillis = currentMillis - StartOfInterval;
if (elapsedMillis >= ResetInterval && !spiState)
StartOfInterval = currentMillis;
elapsedMillis = 0;
rfid.PCD_Reset();
initRfid();
Serial.println("Resetting reader");
if (!spiState) {
rfidCheck();
spiState = !spiState;
