Hi there! I am new to the use of this library, and I am very excited to start it, I loved how it is made.
I want to connect a STM32 Nucleo F746ZG board, it is a Cortex M7 processor, with a display with 800x600px SSD1963 driver, using parallel connection (from buydisplay.com). I am a little dizzy in the method of configuring the MCU pins for each data. In the configuration definition, is the data port a complete port?
- Parallel port
#define LV_DRV_DISP_PAR_CS(val) /par_cs_set(val)/ /Set the Parallel port’s Chip select to ‘val’/
#define LV_DRV_DISP_PAR_SLOW /par_slow()/ /Set low speed on the parallel port/
#define LV_DRV_DISP_PAR_FAST /par_fast()/ /Set high speed on the parallel port/
#define LV_DRV_DISP_PAR_WR_WORD(data) /par_wr(data)/ /Write a word to the parallel port/
#define LV_DRV_DISP_PAR_WR_ARRAY(adr, n) /par_wr_mem(adr,n)/ /Write ‘n’ bytes to Parallel ports from ‘adr’/
Thank you
Pablo
