Good,day! I am a LVGL beginner. I want you to be kind.
Is it possible to move and select objects with three physical buttons for complete control?
M5stack gray,ArduinoIDE
1.Moving the focus.
2.An event to the object being focused.(For example, the click of a button)
3.These clever ways.
If the physical button is pressed, it simulates a button click.
Move and select the focus within a click event.
bool my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
//Click on a button in the screen according to the physical button that is pressed.
if(digitalRead(btn_A)==1){
data->point.x = 10;
data->point.y = screenHeight-10;
}else if(digitalRead(btn_B)==1 ){
data->point.x = screenWidth/2;
}else if(digitalRead(btn_C)==1){
data->point.x = screenWidth-10;
}else{
data->state =LV_INDEV_STATE_REL;
return false;
data->state =LV_INDEV_STATE_PR;
return false; /*Return `false` because we are not buffering and no more data to read*/
static void win_btn_event_handler(lv_obj_t * btn, lv_event_t event)
//Focus processing in the in-screen button event handler.
if(event != LV_EVENT_CLICKED){
return;
if(btn == obj_btn_L){
Serial.println("L");
lv_group_focus_prev(g);
return;
}else if(btn == obj_btn_C){
Serial.println("C");
lv_group_send_data(g,LV_KEY_ENTER);
return;
}else if(btn == obj_btn_R){
Serial.println("R");
lv_group_focus_next(g);
return;
}else{
Serial.println("ex");
Because the M5stack not yet arrived, it is a M5stack-style ESP32.
Thank you!
