Compiler warnings: assignment discards 'const' qualifier from pointer target type
Compiling LVGL (v8.0.2) code (RISC-V GCC, 8.3.0) I see these warnings:
lvgl/src/widgets/lv_checkbox.c:123:13: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/core/lv_obj.c:132:18: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/extra/widgets/tabview/lv_tabview.c:84:25: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/extra/widgets/tabview/lv_tabview.c:93:24: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/extra/widgets/tabview/lv_tabview.c:95:37: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/extra/widgets/tabview/lv_tabview.c:97:37: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
lvgl/src/extra/widgets/tabview/lv_tabview.c:196:21: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
RISC-V (GCC 8.3.0), custom platform
Clean LVGL build with no discarded-qualifiers warnings.
I’d like to treat them as errors (-Werror), but currently LVGL prevents me from doing this.
It should be easy to fix these.
Adding -Wno-discarded-qualifiers option: the build works, but I’d like to avoid having to add this option.
N/A
(cc @kisvegabor)
Currently, our CI uses -Wno-discarded-qualifiers; this would need to be changed if we are going to consider this a disallowed warning.
Unfortunately, I can’t see these warnings with GCC 7.5.0, but I agree that it’d be better to enable them.
If @embeddedt also agrees the enable discarded-qualifiers warnings, @marcinh0001, can you send a PR with the fixes?
I could, but as I explained in another thread, I’m required to add copyright notices to all files I modify, even slightly. I’d like to avoid it, it’s too many files.
Would it be possible for someone else to get rid of discarded-qualifiers warnings?
I can do it, however, I need to find a way of getting them to show up first, as when I enabled -Wdiscarded-qualifiers locally last week, they weren’t appearing.
Thanks. I think you’ll need a sufficiently fussy compiler (probably meaning modern?)
I don’t have a full view of which GCC versions are / aren’t fussy about it, but these two I use definitely are:
  • 8.3.0 for RISC-V
  • 10.2.0 for x86 used under mingw
And, needless to say, you need to get rid of the -Wno-discarded-qualifiers option.
