Hello!
For a project I’m working on, I’ve been implementing a GUI into an barebones embedded C project.
I’m tasked with creating an arc (not using the arc widget) of sorts, that represents information (an integer ranging from 0-9).
This arc is made up of 9 segments that are not connected and seperated by 33,3 degrees around a pivot in the center of the screen.
I’ve implemented this by simply making 9 lines, each line represents a single segment with the coordinates being known at compile-time.
Individual segments have either an “inactive” color, or their own active color.
I recolor using the lv_obj_set_style_line_color() function.
I’m happy with how it looks, but the refresh time isn’t up to par yet. I’ve checked with
#define LV_USE_REFR_DEBUG 1
to see what part of the screen is drawn and I’ve noticed that quite large parts of the screen are being redrawn when a recolor is triggered. It seems that the screen is redrawn from the top-left of the screen, all the way down to the bottom-right edge of the respective segment. In the worst case (the most bottom-right segment), this leads to almost an entire screen redraw.
I expected that only the line itself would be updated, similar to how updating the text in a label only redraws the label.
Renesas R7FA2L1AB with a ILI9341 display
Using the GCC 9.3.1.20200408 toolchain
8.0.2
I want a recoloring of one of the line objects to only trigger a redraw for that line object.
I have tried playing around with switching the parent-object, but nothing seemed to change.
The coordinates are defined on a global scope in the file
//Coordinates of our assist level line segments
CONST STATIC lv_point_t GUIView_assistLinePoints[GUIVIEW_MAX_ASSIST][GUIVIEW_ASSIST_SEGMENT_POINTS] = {
[0] =
{63, 224}, {57, 220}, {50, 214}, {45, 208}, {40, 202}, {36, 195} //Segment 0
[1] =
{28, 179}, {25, 171}, {23, 164}, {22, 156}, {21, 148}, {22, 141} //Segment 1
[2] =
{23, 123}, {25, 115}, {27, 107}, {30, 100}, {34, 93}, {39, 86} //Segment 2
[3] =
{50, 73}, {56, 67}, {62, 62}, {69, 58}, {76, 54}, {83, 51} //Segment 3
[4] =
{100, 45}, {108, 44}, {116, 43}, {124, 43}, {132, 44}, {140, 45} //Segment 4
[5] =
{157, 51}, {164, 54}, {171, 58}, {178, 62}, {184, 67}, {190, 73} //Segment 5
[6] =
{201, 86}, {206, 93}, {210, 100}, {213, 110}, {215, 115}, {217, 123} //Segment 6
[7] =
{219, 141}, {220, 148}, {219, 156}, {218, 165}, {216, 171}, {213, 179} //Segment 7
[8] =
{205, 195}, {200, 202}, {195, 208}, {190, 214}, {183, 220}, {177, 224} //Segment 8
Then in the setup function:
//Declare a style for our assist level segment lines
static lv_style_t style_line;
lv_style_init(&style_line);
lv_style_set_line_width(&style_line, 14);
lv_style_set_line_color(&style_line, GUI_DEFINES_ARC_COLOR_BACKGROUND);
lv_style_set_line_rounded(&style_line, TRUE);
//Create the assist level segments
for(U32BIT i = 0; i < GUIVIEW_MAX_ASSIST; i++)
GUIView_assistLines[i] = lv_line_create(GUIView_mainScreen);
lv_line_set_points(GUIView_assistLines[i], (lv_point_t *)&GUIView_assistLinePoints[i], GUIVIEW_ASSIST_SEGMENT_POINTS);
lv_obj_add_style(GUIView_assistLines[i], &style_line, LV_STATE_DEFAULT);
And lastly, in the update function, we essentially only call the function below for our active segment.
Any help would be much obliged.
Thanks!
