Please see below code and screenshots,
Screenshots,
- The first is an incomplete trace, All good.
- The second is a complete trace, All good.
- The third is 1.5 traces.The newest and oldest points are connected. For me not so good.
My main question is how do I prevent this ?
A second question is how would I achieve the same thing if I were directly setting the points.
IE ser->points[i] = value;
Is there a description on LV_CHART_TYPE_VERTICAL_LINE chart type, how it differs from a normal line chart ?
#define WAVES_TRACES 3/4
//#define WAVES_TRACES 1
//#define WAVES_TRACES 3/2
#define CHART_Y_MAX 100
#define CHART_Y_MIN -CHART_Y_MAX
static lv_coord_t wv_triangle( void )
static bool down;
int32_t delta = CHART_Y_MAX/10;
static int32_t sample = CHART_Y_MIN/10;
sample += down ? -delta : delta;
if( (sample >= CHART_Y_MAX*9/10) ||
(sample <= CHART_Y_MIN*9/10) )
down = !down;
return sample;
static lv_coord_t wv_sawtooth( void )
int32_t delta = CHART_Y_MAX*9/100;
static int32_t sample = CHART_Y_MAX;
sample += delta;
if( sample > CHART_Y_MAX*8/10 )
sample = CHART_Y_MIN*8/10;
return sample;
#include <stdio.h>
void test_chart_create ( lv_obj_t * par )
lv_coord_t w_par = lv_obj_get_width( par );
lv_coord_t h_par = lv_obj_get_height( par );
lv_obj_t * chart = lv_chart_create( par, NULL );
lv_obj_set_size( chart, w_par * 2 / 3, h_par * 2 / 3 );
lv_chart_set_range( chart, CHART_Y_MIN, CHART_Y_MAX );
lv_chart_set_margin( chart, 50 );
lv_chart_set_x_tick_length( chart, 5, 2 );
lv_chart_set_x_tick_texts( chart,
"-12\n-10\n-8\n-6\n-4\n-2\n0",
5,
LV_CHART_AXIS_DRAW_LAST_TICK
lv_chart_set_y_tick_length( chart, 5, 2 );
static char buf[128];
sprintf( buf,
"%d\n%d\n%d\n%d\n%d",
CHART_Y_MAX, CHART_Y_MAX/2,0,CHART_Y_MIN/2,CHART_Y_MIN
lv_chart_set_y_tick_texts( chart,
buf,
5,
lv_obj_align( chart, NULL, LV_ALIGN_CENTER, 0, 0 );
lv_chart_set_type( chart, LV_CHART_TYPE_LINE );
//lv_chart_set_type( chart, LV_CHART_TYPE_VERTICAL_LINE );
static lv_style_t style_chart;
lv_style_copy( &style_chart, &lv_style_pretty );
style_chart.body.opa = LV_OPA_100;
style_chart.body.radius = 0;
style_chart.body.main_color = LV_COLOR_BLACK;
style_chart.body.grad_color = LV_COLOR_BLACK;
style_chart.line.color = LV_COLOR_GRAY;
style_chart.line.width = 1;
lv_chart_set_update_mode( chart, LV_CHART_UPDATE_MODE_CIRCULAR );
lv_chart_set_style( chart, LV_CHART_STYLE_MAIN, &style_chart );
lv_chart_set_series_opa( chart, LV_OPA_100 );
lv_chart_set_series_width( chart, 1 );
lv_chart_set_series_darking( chart, LV_OPA_TRANSP );
uint16_t chart_pnt_cnt = lv_obj_get_width( chart )/8;
lv_chart_set_point_count( chart, chart_pnt_cnt );
lv_chart_series_t * ser1, *ser2;
ser1 = lv_chart_add_series( chart, LV_COLOR_YELLOW );
ser2 = lv_chart_add_series( chart, LV_COLOR_AQUA );
int i, samples = chart_pnt_cnt * WAVES_TRACES;
for( i = 0; i < samples; ++i )
lv_chart_set_next( chart, ser1, wv_triangle() );
lv_chart_set_next( chart, ser2, wv_sawtooth() );
