As per topic title,
It seems that the chart lines extent in the vertical direction (in pixels) beyond the min/max range (set by lv_chart_set_range) by the margin (set by lv_chart_set_margin).
A mouthfull, but I am sure you get the drift
visual_studio_2017_sdl simulator
What do you experience?
As described above
What do you expect?
Informing you and hoping it will be fixed, unless I am not doing something correcly.in which case I will gladly take any advice.
#define CHART_SET_MARGIN 1
#define CHART_SET_TICKS 1
static void test_chart_create ( lv_obj_t * par )
lv_coord_t w_par = lv_obj_get_width( par );
lv_coord_t h_par = lv_obj_get_height( par );
static lv_style_t style_chart;
lv_style_copy( &style_chart, &lv_style_pretty );
style_chart.body.opa = LV_OPA_60;
style_chart.body.radius = 0;
style_chart.line.color = LV_COLOR_GRAY;
lv_obj_t * chart = lv_chart_create( par, NULL );
lv_obj_set_size( chart, w_par*2/3, h_par*2/3 );
lv_chart_set_range( chart, 0, 100 );
#if CHART_SET_MARGIN
lv_chart_set_margin( chart, 40 );
#if CHART_SET_TICKS
lv_chart_set_x_tick_length( chart, 5, 2 );
lv_chart_set_x_tick_texts( chart,
"-10\n0\n10\n20\n30\n40\n50",
7,
LV_CHART_AXIS_DRAW_LAST_TICK
lv_chart_set_y_tick_length( chart, 5, 2 );
lv_chart_set_y_tick_texts( chart,
"100\n75\n50\n25\n0",
5,
lv_chart_set_type( chart, LV_CHART_TYPE_POINT | LV_CHART_TYPE_LINE );
lv_chart_set_style( chart, LV_CHART_STYLE_MAIN, &style_chart );
lv_chart_set_series_opa( chart, LV_OPA_70 );
lv_chart_set_point_count( chart, 20 );
lv_chart_series_t * ser1, *ser2;
ser1 = lv_chart_add_series( chart, LV_COLOR_RED );
ser2 = lv_chart_add_series( chart, LV_COLOR_GREEN );
int i;
for( i = 0; i < 20; ++i )
ser1->points[i] = -20 + i*5;
ser2->points[i] = -20 + i*10;
lv_chart_refresh( chart );
lv_obj_align( chart, NULL, LV_ALIGN_CENTER, 0, 0 );
Screenshots
With Margin,
#define CHART_SET_TICKS 1 /* Or 0 */
#define CHART_SET_MARGIN 0
#define CHART_SET_TICKS 0 /* Or 1 */
