Raspberry Pi 4 with Linux Frame Buffer
v8.0
I am trying to display sensor data stored as integers representing a fixed point value (integers between 0 and 1400 representing sensor values from 0.00 to 14.00). I can display this data easily with the chart widget however I want the text on the tick labels to match the true fixed point value not the integer value.
My current solution is modifying the line in lv_chart.c that sets the label text from
lv_snprintf(dsc.text, sizeof(dsc.text), "%d", tick_value);
to
uint8_t scale_factor = 100;
lv_snprintf(dsc.text, sizeof(dsc.text), "%d.%d", tick_value/scale_factor, tick_value%scale_factor);
This method works but it feels like a hack and I would prefer not to branch from the source widgets. Is there a “correct” way to achieve this?
The other two alternatives I have thought of are:
- Disable the tick labels and create them from scratch manually.
- Use an empty secondary axis to create the labels.
lv_obj_t *chart;
lv_obj_t *series_ph;
//Create chart
chart = lv_chart_create(lv_scr_act());
lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
lv_obj_set_size(chart, 200, 200);
lv_obj_center(chart);
//Add data
series_ph = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_CIRCULAR);
lv_chart_set_point_count(chart, 50);
lv_chart_set_all_value(chart, series_ph, 700);
//Setup primary y axis
lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, 0, 1400);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 10, 5, 8, 2, true, 50);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 10, 5, 3, 5, true, 20);
