Hello, I’m working with LVGL 9.3 and an ESP32P4 connected to a 1280x720 MIPI-DSI display.
My main widget on the screen is a Scatter Chart object. I noticed that when I increase the size of the widget, say from 600x300 to 1100x500, my FPS (as reported by LVGL performace metrics) drops significantly! (from ~60fps to ~8).
I’m not changing the chart axis limits, the data being presented on it, nor anything else about the ‘chart’ itself, solely the object width/height!
My chart updates every 100ms with a point count of 25. The data input is random values using lv_rand. Axis limits are 0-200x0-200.
Bug? Feature? Did I miss something?
Any help or insight would be much appreciated!
CODE SNIPPETS BELOW:
New data uses “lv_chart_set_next_value2” and “lv_rand” to generate the values
(These are mostly taken from lvgl scatter example…)
//Main chart config:
void ConfigureScatterChart(void){
lv_chart_set_type(objects.lidar_chart, LV_CHART_TYPE_SCATTER);
lv_obj_set_flag(objects.lidar_chart, LV_OBJ_FLAG_SEND_DRAW_TASK_EVENTS, true);
lv_obj_set_style_line_width(objects.lidar_chart, 0, LV_PART_ITEMS); //Remove the lines
lv_obj_set_style_size(objects.lidar_chart, 8, 8, LV_PART_INDICATOR); // Set dot dimensions
lv_chart_set_axis_range(objects.lidar_chart, LV_CHART_AXIS_PRIMARY_X, 0, ChartMaxX);
lv_chart_set_axis_range(objects.lidar_chart, LV_CHART_AXIS_PRIMARY_Y, 0, ChartMaxY);
lv_chart_set_point_count(objects.lidar_chart, 25);
lv_timer_create(add_data, 100, objects.lidar_chart);
//100mS chart refresh:
void action_chart_refresh(lv_event_t \*e) {
lv_draw_task_t \* draw_task = lv_event_get_draw_task(e);
lv_draw_dsc_base_t \* base_dsc = (lv_draw_dsc_base_t\*)lv_draw_task_get_draw_dsc(draw_task);
if(base_dsc->part != LV_PART_INDICATOR) return;
lv_obj_t \* obj = lv_event_get_target_obj(e);
lv_chart_series_t \* ChartDataSeries = lv_chart_get_series_next(obj, NULL);
lv_draw_fill_dsc_t \* fill_draw_dsc = lv_draw_task_get_fill_dsc(draw_task);
if(fill_draw_dsc == NULL) return;
uint32_t cnt = lv_chart_get_point_count(obj);
fill_draw_dsc->opa = (lv_opa_t)((LV_OPA_COVER \* base_dsc->id2) / (cnt - 1));
if(ThemeMode == false){
fill_draw_dsc->color = lv_color_hex(0xFDFD35);
} else{
fill_draw_dsc->color = lv_color_hex(0x29201D);
Thanks!
