Cannot seem to set the color of an arc’s indicator
Using Simulator on Mac
lvgl 8.3.7
After several straight forward attempts, I looked for an example which was similar. I found a slider example and while I attempted to do what it does (to the arc), it didn’t work. So, I literally copied the slider code into my project just to see the slider would work. It did! And then when I change from lv_slider_create() to lv_arc_create(), it no longer works. Hmm.
I am able to change the background of the arc via lv_style_set_arc_color(), BTW. But not the indicator portion.
void lv_example_slider_2(void)
/*Create a transition*/
static const lv_style_prop_t props[] = {LV_STYLE_BG_COLOR, (lv_style_prop_t)0};
static lv_style_transition_dsc_t transition_dsc;
lv_style_transition_dsc_init(&transition_dsc, props, lv_anim_path_linear, 300, 0, NULL);
static lv_style_t style_main;
static lv_style_t style_indicator;
static lv_style_t style_knob;
static lv_style_t style_pressed_color;
lv_style_init(&style_main);
lv_style_set_bg_opa(&style_main, LV_OPA_COVER);
lv_style_set_bg_color(&style_main, lv_color_hex3(0xbbb));
lv_style_set_radius(&style_main, LV_RADIUS_CIRCLE);
lv_style_set_pad_ver(&style_main, -2); /*Makes the indicator larger*/
lv_style_init(&style_indicator);
lv_style_set_bg_opa(&style_indicator, LV_OPA_COVER);
lv_style_set_bg_color(&style_indicator, lv_palette_main(LV_PALETTE_CYAN));
lv_style_set_radius(&style_indicator, LV_RADIUS_CIRCLE);
lv_style_set_transition(&style_indicator, &transition_dsc);
lv_style_init(&style_knob);
lv_style_set_bg_opa(&style_knob, LV_OPA_COVER);
lv_style_set_bg_color(&style_knob, lv_palette_main(LV_PALETTE_CYAN));
lv_style_set_border_color(&style_knob, lv_palette_darken(LV_PALETTE_CYAN, 3));
lv_style_set_border_width(&style_knob, 2);
lv_style_set_radius(&style_knob, LV_RADIUS_CIRCLE);
lv_style_set_pad_all(&style_knob, 6); /*Makes the knob larger*/
lv_style_set_transition(&style_knob, &transition_dsc);
lv_style_init(&style_pressed_color);
lv_style_set_bg_color(&style_pressed_color, lv_palette_darken(LV_PALETTE_CYAN, 2));
/*Create a slider and add the style*/
// _doesnt_ work lv_obj_t * slider = lv_arc_create(lv_scr_act());
lv_obj_t * slider = lv_slider_create(lv_scr_act());
lv_obj_remove_style_all(slider); /*Remove the styles coming from the theme*/
lv_obj_add_style(slider, &style_main, LV_PART_MAIN);
lv_obj_add_style(slider, &style_indicator, LV_PART_INDICATOR);
lv_obj_add_style(slider, &style_pressed_color, LV_PART_INDICATOR | LV_STATE_PRESSED);
lv_obj_add_style(slider, &style_knob, LV_PART_KNOB);
lv_obj_add_style(slider, &style_pressed_color, LV_PART_KNOB | LV_STATE_PRESSED);
lv_obj_center(slider);
