Hi all, i would like to format y labels in a certain way: if i got 100, i want to print 1, so i need to divide the number i got by 100, having at max 1 decimal.
ESP32S3
8.2.0
Having the graph labels formatted as follows: x/100 where x is the number to print at tick label.
In my application i update the range of the graph periodically, so the labels must change with the format i want as the program goes
I tried some solutions in web but none worked
One of the examples in the documentation for lv_chart shows how to attach a callback to LV_EVENT_DRAW_PART_BEGIN so you can intercept when these get drawn and modify them as you please for the X axis - presumably it works for the Y axis too!
Hi, i have tried exaclty that code, but it seems not to work, because i need to format the labels multiple times.
I think it is because of the event type
static void draw_event_cb(lv_event_t * e)
lv_obj_draw_part_dsc_t *dsc = lv_event_get_draw_part_dsc(e);
if (dsc->class_p == &lv_chart_class && dsc->part == LV_CHART_PART_TICKS && dsc->id == LV_CHART_AXIS_PRIMARY_Y && dsc->text) {
// Divide il valore per 100
float value = *((float *)dsc->value);
value /= 100.0;
// Formatta il testo delle etichette con il nuovo valore
lv_snprintf(dsc->text, dsc->text_length, "%.1f", value);
Your code may result in an exception because of this line:
dsc->value is int32_t. It means it is a value and not a pointer to anything. So you should not cast this to a pointer (of any type) as you do. If you do this it might throw an exception because of illegal address access.
This code converts the int32_t value to a float value.
float value = (float) dsc->value;
value /= 100.0;
or in one line:
float value = (float) dsc->value / 100.0;
When you use lv_snprintf with float numbers you have to setup lv_conf.h appropriately. Look for LV_SPRINTF_USE_FLOAT. It should be set to 1 in case LV_SPRINTF_CUSTOM is set to 0
Managed to make it work by removing some conditions in the if guard.
here is the code.
Do you confirm that is correct? Thank you for your help and your time
if (dsc->id == LV_CHART_AXIS_PRIMARY_Y) {
lv_snprintf(dsc->text, dsc->text_length, "%.1f", (float) dsc->value / 100.0);
// call this function when you init the ui
lv_obj_add_event_cb(ui_VoltageChart, draw_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
