I have two variables (uint) that I want to change with just one button depending on the position of a switch button. The button should add a certain numerical value to the variable. This value is shown on the display using a label. I have tried a wide variety of methods. If statement for calling two different events. Calling the event and querying what the switch button is in. I manage to get one numerical value to change and be displayed. If I then change the switch, the label changes from the previous numerical value to the numerical value that is actually assigned to the other label.
Arduino IDE (latest), Arduino Giga R1 WiFi with Display Shield
9.1.0
That I can use a switch and a button to change two variables based on the switch state.
see above.
int setpressurecrucible = 234;
int setpressurespraychamber = 52;
bool switch_state = false;
uint helper_uint = 0;
uint cpressure_uint = 0;
uint spressure_uint = 0;
lv_obj_t* tile = lv_tileview_add_tile(tv, 0, 0, LV_DIR_BOTTOM);
lv_obj_t* lbl_cpressure = lv_label_create(tile);
lv_obj_t* arc = lv_arc_create(tile);
lv_obj_set_size(arc, 200, 200);
lv_arc_set_angles(arc, 150, 45);
lv_arc_set_value(arc, 62);
lv_arc_set_range(arc, 0, 2500);
lv_obj_remove_style(arc, NULL, LV_PART_KNOB);
lv_obj_align(arc, LV_ALIGN_TOP_LEFT, 30, 30);
lv_label_set_text_fmt(lbl_cpressure, "%d\nmbar", 1276);
lv_obj_set_width(lbl_cpressure, 100);
lv_obj_set_style_text_align(lbl_cpressure, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align_to(lbl_cpressure, arc, LV_ALIGN_CENTER, 0, -45);
lv_obj_set_style_text_font(lbl_cpressure, &lv_font_montserrat_32, 0);
lv_obj_add_event_cb(arc, value_changed_event_cb, LV_EVENT_VALUE_CHANGED, lbl_cpressure);
/*Manually update the label for the first time*/
lv_obj_send_event(arc, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_t* lbl_setcpressure = lv_label_create(tile);
lv_label_set_text_fmt(lbl_setcpressure, "(%d)", setpressurecrucible);
lv_obj_set_width(lbl_setcpressure, 100);
lv_obj_set_style_text_align(lbl_setcpressure, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align_to(lbl_setcpressure, arc, LV_ALIGN_CENTER, 0, 20);
lv_obj_set_style_text_font(lbl_setcpressure, &lv_font_montserrat_28, 0);
lv_obj_t* lbl_spressure = lv_label_create(tile);
lv_obj_t* arcs = lv_arc_create(tile);
lv_obj_set_size(arcs, 200, 200);
lv_arc_set_angles(arcs, 170, 310);
lv_arc_set_value(arcs, 62);
lv_arc_set_range(arcs, 0, 1500);
lv_obj_remove_style(arcs, NULL, LV_PART_KNOB);
lv_obj_align(arcs, LV_ALIGN_TOP_RIGHT, -30, 30);
lv_label_set_text_fmt(lbl_spressure, "%d\nmbar", 106);
lv_obj_set_width(lbl_spressure, 100);
lv_obj_set_style_text_align(lbl_spressure, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align_to(lbl_spressure, arcs, LV_ALIGN_CENTER, 0, -45);
lv_obj_set_style_text_font(lbl_spressure, &lv_font_montserrat_32, 0);
lv_obj_add_event_cb(arcs, value_changed_event_cb_s, LV_EVENT_VALUE_CHANGED, lbl_spressure);
lv_obj_send_event(arcs, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_t* lbl_setspressure = lv_label_create(tile);
lv_label_set_text_fmt(lbl_setspressure, "(%d)", setpressurespraychamber);
lv_obj_set_width(lbl_setspressure, 100);
lv_obj_set_style_text_align(lbl_setspressure, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align_to(lbl_setspressure, arcs, LV_ALIGN_CENTER, 0, 20);
lv_obj_set_style_text_font(lbl_setspressure, &lv_font_montserrat_28, 0);
lv_obj_t* label;
static lv_obj_t* btn_5mbar = lv_button_create(tile);
lv_obj_add_event_cb(btn_5mbar, plus_5_event_handler, LV_EVENT_CLICKED, lbl_setcpressure);
lv_obj_align(btn_5mbar, LV_ALIGN_OUT_TOP_MID, 250, 30);
lv_obj_remove_flag(btn_5mbar, LV_OBJ_FLAG_PRESS_LOCK);
label = lv_label_create(btn_5mbar);
lv_label_set_text(label, "+5");
lv_obj_center(label);
lv_obj_set_style_text_font(label, &lv_font_montserrat_32, 0);
lv_obj_t* sw;
sw = lv_switch_create(tile);
lv_obj_add_event_cb(sw, sw_event_handler, LV_EVENT_VALUE_CHANGED, lbl_toggle);
lv_obj_add_flag(sw, LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_align(sw, LV_ALIGN_CENTER, 0, -78);
lv_obj_t* label7;
label7 = lv_label_create(tile);
lv_label_set_text(label7, "Crucible");
lv_obj_center(label7);
lv_obj_align(label7, LV_ALIGN_CENTER, -70, -78);
lv_obj_t* label8;
label8 = lv_label_create(tile);
lv_label_set_text(label8, "Spraychamber");
lv_obj_center(label8);
lv_obj_align(label8, LV_ALIGN_CENTER, 90, -78);
static void plus_5_event_handler(lv_event_t* e) {
if (code == LV_EVENT_SHORT_CLICKED) {
if (!switch_state) {
lv_obj_t* lbl_setcpressure = (lv_obj_t*)lv_event_get_param(e);
setpressurecrucible = pressure_set(5);
} else if (switch_state) {
lv_obj_t* lbl_setspressure = (lv_obj_t*)lv_event_get_param(e);
setpressurespraychamber = pressure_set(5);
static void value_changed_event_cb(lv_event_t* e) {
lv_obj_t* arc = (lv_obj_t*)lv_event_get_target(e);
lv_obj_t* lbl_cpressure = (lv_obj_t*)lv_event_get_user_data(e);
helper_uint = lv_arc_get_value(arc);
cpressure_uint = helper_uint - 1000;
lv_label_set_text_fmt(lbl_cpressure, "%d\nmbar", cpressure_uint);
static void value_changed_event_cb_s(lv_event_t* e) {
lv_obj_t* arcs = (lv_obj_t*)lv_event_get_target(e);
lv_obj_t* lbl_spressure = (lv_obj_t*)lv_event_get_user_data(e);
helper_uint = lv_arc_get_value(arcs);
spressure_uint = helper_uint - 1000;
lv_label_set_text_fmt(lbl_spressure, "%d\nmbar", spressure_uint);
Not at hand right now
