I am writing an application that is using at least three screens to perform actions and display data.
I have searched the internet and I have found many people asking what is the correct way to do this, but I have not come across an example that works for me.
At present, every time I try to change screens, the ESP32 restarts with:
“Guru Meditation Error: Core 1 panic’ed (InstrFetchProhibited). Exception was unhandled.”
Espressive ESP32-S3-WROOM-1
Currently using 8.3.0 - I have also tried the latest
I am looking to put together an example that I can use and share with others that are having the same problem as me.
Too many examples to mention here…
//******************************* MY CODE *******************************************
//screen1 = lv_scr_act();
screen1 = lv_obj_create(NULL);
lv_obj_t * button1 = lv_btn_create(screen1);
lv_obj_add_event_cb(button1, button_event_cb, LV_EVENT_CLICKED, NULL);
lv_obj_set_size(button1, 170, 80);
lv_obj_set_pos(button1, 32, 100);
lv_obj_t * label1 = lv_label_create(button1);
lv_label_set_text(label1, "Button 1");
lv_obj_t * button2 = lv_btn_create(screen1);
lv_obj_add_event_cb(button2, button_event_cb, LV_EVENT_CLICKED, NULL);
lv_obj_set_size(button2, 170, 80);
lv_obj_set_pos(button2, 249, 100);
lv_obj_t * label2 = lv_label_create(button2);
lv_label_set_text(label2, "Button 2");
screen2 = lv_obj_create(NULL);
//lv_scr_load(screen2);
lv_obj_t * button3 = lv_btn_create(screen2);
lv_obj_add_event_cb(button3, button_event_cb, LV_EVENT_CLICKED, NULL);
lv_obj_set_size(button3, 170, 80);
lv_obj_set_pos(button3, 249, 100);
lv_obj_t * label3 = lv_label_create(button2);
lv_label_set_text(label3, "Button 3");
screen3 = lv_obj_create(NULL);
//lv_scr_load(screen3);
lv_scr_load(screen1);
// lv_scr_load(screen3);
printf("Setup done\n");
void loop()
delay(5);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
//espnow_senddata();
void button_event_cb(lv_event_t *event){
//lv_obj_t *screen1;
lv_obj_t *screen2;
//lv_obj_t *screen3;
lv_obj_t *btn = lv_event_get_target(event);
lv_obj_t * label = lv_obj_get_child(btn, 0);
const char * text = lv_label_get_text(label);
printf ("Button_Touched: %s \n", text);
if(strcmp(text, "Button 2") == 0) {
printf ("Goto Screen: %s \n", text);
//lv_scr_load(scn2);
//lv_obj_clean(lv_scr_act());
//lv_scr_load(lv_scr_act());
printf ("Clean Screen1:\n");
lv_obj_clean(screen1);
printf ("Delete Screen1:\n");
lv_obj_del(screen1);
//printf ("Clean Screen2:\n");
//lv_obj_clean(screen2);
//printf ("Delete Screen2:\n");
//lv_obj_del(screen2);
printf ("Load Screen3:\n");
//Comment
// void button2_event_cb(lv_event_t *event)
// // if(event == LV_EVENT_CLICKED) {
// lv_scr_load(lv_scr_act());
21224][E][Wire.cpp:�ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbe4
load:0x403cc700,len:0x2a38
entry 0x403c98d4
[ 129][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
[ 701][I][esp32-hal-i2c.c:75] i2cInit(): Initialising I2C Master: sda=19 scl=20 freq=100000
[ 701][W][Wire.cpp:301] begin(): Bus already started in Master Mode.
[ 704][E][esp32-hal-gpio.c:102] __pinMode(): Invalid pin selected
E (582) gpio: gpio_set_level(226): GPIO output gpio_num error
E (597) gpio: gpio_set_level(226): GPIO output gpio_num error
E (603) gpio: gpio_set_level(226): GPIO output gpio_num error
[ 781][E][esp32-hal-gpio.c:102] __pinMode(): Invalid pin selected
Setup done
Button_Touched: Button 1
Button_Touched: Button 2
Goto Screen: Button 2
Clean Screen1:
Delete Screen1:
Load Screen3:
Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x00000205 PS : 0x00060030 A0 : 0x82002cb7 A1 : 0x3fceba30
A2 : 0x00000205 A3 : 0x3fceba74 A4 : 0x3fc973a8 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x8204a9ad A9 : 0x3fceba00
A10 : 0x3fc973a8 A11 : 0x3fceba74 A12 : 0x3fca4720 A13 : 0x3c0508e7
A14 : 0x3c050831 A15 : 0x3c050841 SAR : 0x0000000a EXCCAUSE: 0x00000014
EXCVADDR: 0x00000204 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xfffffff0
Backtrace: 0x00000202:0x3fceba30 0x42002cb4:0x3fceba50 0x42002e5e:0x3fceba70 0x420091de:0x3fcebab0 0x42009739:0x3fcebae0 0x42009bff:0x3fcebb00 0x42006429:0x3fcebb20 0x4200646d:0x3fcebb50 0x420029ac:0x3fcebb70 0x42002c65:0x3fcebc30 0x420024ae:0x3fcebc50 0x42002e02:0x3fcebc70 0x42002e5e:0x3fcebc90 0x4200344e:0x3fcebcd0 0x42003b04:0x3fcebd00 0x42019000:0x3fcebd50 0x420026bf:0x3fcebd80 0x4202b251:0x3fcebda0
#0 0x00000202:0x3fceba30 in ?? ??:0
#1 0x42002cb4:0x3fceba50 in event_send_core at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_event.c:458
#2 0x42002e5e:0x3fceba70 in lv_event_send at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_event.c:75
#3 0x420091de:0x3fcebab0 in lv_obj_refresh_style at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_style.c:187
(inlined by) lv_obj_refresh_style at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_style.c:167
#4 0x42009739:0x3fcebae0 in lv_obj_set_local_style_prop at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_style.c:275
#5 0x42009bff:0x3fcebb00 in lv_obj_set_style_x at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_style_gen.c:56
#6 0x42006429:0x3fcebb20 in lv_obj_set_x at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_pos.c:62
#7 0x4200646d:0x3fcebb50 in lv_obj_set_pos at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_obj_pos.c:48
#8 0x420029ac:0x3fcebb70 in lv_scr_load_anim at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_disp.c:232
#9 0x42002c65:0x3fcebc30 in lv_disp_load_scr at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_disp.c:84
#10 0x420024ae:0x3fcebc50 in button_event_cb(_lv_event_t*) at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_disp.h:207
(inlined by) button_event_cb(_lv_event_t*) at src/main.cpp:256
#11 0x42002e02:0x3fcebc70 in event_send_core at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_event.c:467
#12 0x42002e5e:0x3fcebc90 in lv_event_send at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_event.c:75
#13 0x4200344e:0x3fcebcd0 in indev_proc_release at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_indev.c:980
#14 0x42003b04:0x3fcebd00 in indev_pointer_proc at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_indev.c:384
(inlined by) lv_indev_read_timer_cb at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/core/lv_indev.c:101
#15 0x42019000:0x3fcebd50 in lv_timer_exec at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/misc/lv_timer.c:313
(inlined by) lv_timer_handler at .pio/libdeps/esp32-s3-Sunton_800x480/lvgl/src/misc/lv_timer.c:109
#16 0x420026bf:0x3fcebd80 in loop() at src/main.cpp:217
#17 0x4202b251:0x3fcebda0 in loopTask(void*) at C:/Users/dpunt/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:50
ELF file SHA256: 4db1e7f78ea52109
Rebooting...
