Change luminosity or brightness
Hello everyone, how can I change the luminosity or brightness of the screen with a slider
PC_Simulator
You’d want to get the slider’s value and then adjust the brightness using whatever method is appropriate to your platform. LittlevGL does not have any built-in feature for manipulating screen brightness.
Ok, Thanks))
As @embeddedt said, you want to control the physical screen brightness, usually using a PWM input to the screen, usually designated “LITE” or something like that.
Roughly how I have done it successfully in my ESP32 projects.
#define BACKLIGHT_CHANNEL 0
#define BACKLIGHT_FREQUENCY 12000
#define BACKLIGHT_RESOLUTION_BITS 8
#define TFT_LITE 33
pinMode(TFT_LITE, OUTPUT);
ledcSetup(BACKLIGHT_CHANNEL, BACKLIGHT_FREQUENCY, BACKLIGHT_RESOLUTION_BITS);
float percent = 0.75;
int dutyCycle = (int) round(255 * percent);
ledcWrite(BACKLIGHT_CHANNEL, dutyCycle);
Good luck!
Thank you, there will be time, I will definitely test))))
