epikao
September 1, 2023, 12:54pm
1
How can I change the color from arc indicator during runtime (not at initialization), see picture red arrow?
I already tried different codes but without success (see below)
lv_obj_remove_style(ui.screen_arc_1, &style_screen_arc_1_main_indicator_default, LV_PART_INDICATOR|LV_STATE_DEFAULT);
lv_style_set_arc_color(&style_screen_arc_1_main_indicator_default, lv_color_make(0x00, 0x00, 0xff));
lv_obj_add_style(ui.screen_arc_1, &style_screen_arc_1_main_indicator_default, LV_PART_INDICATOR|LV_STATE_DEFAULT);
or
lv_obj_remove_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_ARC_DRAW_PART_FOREGROUND);
lv_style_set_arc_color(&style_screen_arc_1_main_knob_default, lv_color_make(0x00, 0x00, 0xff));
lv_obj_add_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_ARC_DRAW_PART_FOREGROUND);
Thank you
Try this
lv_obj_set_style_arc_color(ui.screen_arc_1, lv_color_hex(0x4040FF), LV_PART_INDICATOR | LV_STATE_DEFAULT );
epikao
September 1, 2023, 2:07pm
3
sorry, I forgot to mention, that I use lvgl version 8.3.7
epikao
September 5, 2023, 12:14pm
4
I now try to change to color of knob too, but that does not work. See below my code:
What’s wrong here?
lv_obj_remove_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_STATE_DEFAULT);
lv_obj_set_style_arc_color(ui.screen_arc_1, lv_color_make(0xff, 0x00, 0x00), LV_PART_KNOB|LV_STATE_DEFAULT);
lv_obj_add_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_STATE_DEFAULT);
Hi @epikao ,
I am a little confused by your code but I think if you just have the second line it will work fine:
//lv_obj_remove_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_STATE_DEFAULT);
//lv_obj_add_style(ui.screen_arc_1, &style_screen_arc_1_main_knob_default, LV_PART_KNOB|LV_STATE_DEFAULT);
In your original code the first line removes the style from the object(I don’t know why? ) Then you are directly modifying the colour of the knob with the next line, which will change the colour but in the third line you are then adding the unmodified style back to the object which will overwrite the direct change in the previous line if that makes sense?
Or you could do this to continue using the style_screen_arc_1_main_knob_default style which is defined:
lv_style_set_arc_color(&style_screen_arc_1_main_knob_default, lv_color_make(0xff, 0x00, 0x00) );
I hope that helps
Kind Regards,
Pete
epikao
September 5, 2023, 2:03pm
6
Thank you.
If I don’t remove the object and change the color during runtime too frequently, I encounter a hard fault.
Following code works:
lv_style_set_bg_color(&style_screen_arc_1_main_knob_default, lv_color_make(0xff, 0xff, 0xff));
