I’m trying to change images in run-time. Basically a image that will change depending on the Battery Level. Problem is, When I either:
- Try to change the image directly
- Delete the Object
My Device (ESP32) crashes with the following:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4204bed7 PS : 0x00060630 A0 : 0x82004294 A1 : 0x3fcebb50
A2 : 0x00000000 A3 : 0x00ffffff A4 : 0x80377fa7 A5 : 0x3fcf4bf0
A6 : 0x00000001 A7 : 0x3fce9dc0 A8 : 0x00000020 A9 : 0x80000000
A10 : 0x3fca4ccc A11 : 0x3fca4ccc A12 : 0x80000020 A13 : 0x00000007
A14 : 0x00000005 A15 : 0x00000001 SAR : 0x0000001a EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000008 LBEG : 0x4200c7b4 LEND : 0x4200c7d2 LCOUNT : 0x00000000
Backtrace: 0x4204bed4:0x3fcebb50 0x42004291:0x3fcebb70 0x420075fd:0x3fcebba0 0x42001f59:0x3fcebbc0 0x420020a3:0x3fcebbe0 0x4202919e:0x3fcebc50
Part of my code is this (took all of the unimportant stuff):
float perc = 5;
lv_obj_t * batteryLevelImg;
LV_IMG_DECLARE(BatteryFull);
LV_IMG_DECLARE(BatteryHalf);
LV_IMG_DECLARE(BatteryLow);
LV_IMG_DECLARE(BatteryEmpty);
void setup() {
BatterySetup();
delay( 500 );
//BatteryLevelImage();
void BatterySetup() {
lv_obj_t * batteryLevelImg = lv_img_create(lv_scr_act());
lv_img_set_src(batteryLevelImg, &BatteryFull);
lv_obj_align(batteryLevelImg, LV_ALIGN_CENTER, 0, -70);
void BatteryLevelImage() {
lv_obj_del(batteryLevelImg);
delay(50);
/*if (perc < 10) {
lv_img_set_src(batteryLevelImg, &BatteryEmpty);
} else if (perc < 30)
lv_img_set_src(batteryLevelImg, &BatteryLow);
} else if (perc < 80)
lv_img_set_src(batteryLevelImg, &BatteryHalf);
} else {
Crash happens on BatteryLevelImage(). Both lv_img_set_src() to the existing variables, as well as deleting the image object result in a crash.
Creating more images are not a problem, but removing / changing the old ones are!
The images are 32x32 pixels CF_TRUE_COLOR and the C array files are about 57Kb.
So I’d be willing to say it’s not a memory Issue.
