Change color of textarea cursor
stm32
8.3
how to change the color of the cursor of the textarea?
Capture
I second this question.
Thought I would answer it but nothing seems to work. Creating a style, setting the border properties and adding to the text area as LV_PART_CURSOR has no effect on the cursor.
This is what I did in the micropython sim
@embeddedt - any thoughts?
style = lv.style_t()
style.init()
style.set_border_color(lv.palette_main(lv.PALETTE.BLUE))
style.set_border_width(5)
style.set_border_opa(lv.OPA._80)
scr = lv.obj()
ta = lv.textarea(scr)
ta.add_style(style, lv.PART.CURSOR)
Because of the way style precedence works, you need to apply the style to lv.PART.CURSOR | lv.STATE.FOCUSED, otherwise the default theme takes priority since that’s the selector it uses.
style.init()
scr = lv.obj()
ta.add_style(style, lv.PART.CURSOR | lv.STATE.FOCUSED)
lv.scr_load(scr)
Thanks. Good to know.
So the take away here is if a style isn’t working the way you expect, check how it is being configured in the default theme.
I added style to the text area.
It worked, thank both of you very much
:+1: :+1:
