RXX
November 20, 2020, 3:56pm
1
how to change the color and font i am using functions for the speed of writing code, but I ran into the problem that if i call the function twice, then the color and font will be with the value of the last
esp32
lv_obj_t * label_new(lv_obj_t *cont, char *title, int *x_pos, int *y_pos, const lv_font_t *font_lb, lv_color_t color)
static lv_style_t style_label_bg;
lv_style_copy(&style_label_bg, &lv_style_plain);
style_label_bg.text.color = color;
style_label_bg.text.font = font_lb;
lv_obj_t *label1 = lv_label_create(cont, NULL);
lv_label_set_text(label1, title);
lv_obj_set_pos(label1, x_pos, y_pos);
lv_label_set_style(label1,LV_LABEL_STYLE_MAIN, &style_label_bg);
return label1
style_label_bg is static, meaning that you are referencing the same style in both calls of the function. You would need to allocate it on the heap using lv_mem_alloc. Depending on whether you are planning to delete the label or not you may need to keep a reference to the style pointer so you can free it later.
In v7 you would be able to just use the local style that every object has on it (you wouldn’t need to create a separate style instance), but there’s no way around that for v6.
RXX
November 20, 2020, 4:32pm
4
i did, only i got a memory leak
lv_style_t *style_lb = lv_mem_alloc(sizeof(lv_style_t));
lv_style_copy(style_lb, &lv_style_plain);
style_lb->text.color = color;
style_lb->text.font = font_lb;
lv_label_set_style(label1, LV_LABEL_STYLE_MAIN, style_lb);
return label1;
Sounds like you are creating the label over and over without deleting the previous style. As I mentioned before you will need to keep track of the style reference and free it after deleting the label.
RXX
November 23, 2020, 10:45am
7
what am I doing wrong?
lv_style_t *style_lb;
lv_obj_t * label_create(lv_obj_t *cont, char *title, int *x_pos, int *y_pos, const lv_font_t *font_lb, lv_color_t color) // this function create
style_lb = (lv_style_t*)lv_mem_alloc(sizeof(lv_style_t));
return label1;
and second function
lv_mem_free(style_lb);
flag_screen = 25;
black_screen1();
lv_obj_del(black_screen);
Freeing the style before deleting the object sounds very suspicious.
Ok, one thing I forgot: you need to call lv_style_reset(style_lb) before freeing it.
RXX
November 23, 2020, 1:11pm
11
embeddedt:
MB it for version v7?
error: implicit declaration of function 'lv_style_reset'; did you mean 'lv_style_init'?
Right; I forgot that you are using v6. You shouldn’t need that for v6 as styles are just a collection of basic variables.
Hmm… maybe you should try commenting out the style_lb related code and see if the memory leak still happens.
RXX
November 23, 2020, 2:29pm
13
no, everything is working correctly
with style_lb
without style_lb
RXX
November 24, 2020, 9:54am
14
does anyone else have any thoughts?
RXX
November 24, 2020, 11:08am
15
my decision @embeddedt check please)
int inc_label = 0;
lv_style_t *style_lb[10];
style_lb[inc_label] = (lv_style_t *) malloc(sizeof(lv_style_t));
lv_style_copy(style_lb[inc_label], &lv_style_plain);
style_lb[inc_label]->text.color = color;
style_lb[inc_label]->text.font = font_lb;
lv_label_set_style(label1, LV_LABEL_STYLE_MAIN, style_lb[inc_label]);
inc_label++;
return label1;
and before the place where I call the function
if(inc_label > 0) {
for(int i=0; i<inc_label; i++) {
free(style_lb[i]);
inc_label=0;
the problem was that I called the function several times, and cleared the last label, I was inattentive
Glad you figured it out!
You could also use the label’s user data pointer to store the style reference. Either solution works.
