Change animation speed in tabview?
How do I change the animation speed in tabview. Instead of the slow sliding animation, I would like it to change fast - it doesn’t even need to slide. Just a fast change.
ESP32 with arduino on a 480x320 display
8.3.7
Change the animation speed when a tab button is changed
Seen how it´s done in version 7, but that doesn’t work anymore
    lv_obj_t* tabView = lv_tabview_create(myScreen, LV_DIR_TOP, 30);
    lv_obj_t* tab1 = lv_tabview_add_tab(tabView, "Tab1");
    lv_obj_t* tab2 = lv_tabview_add_tab(tabView, "Tab2");
Hi @AlexJ ,
You need to override the default scroll event with a custom event handler…
Hopefully this code will do the trick for you…
static void scroll_begin_event_cb(lv_event_t* e)
    /*Disable the scroll animations. Triggered when a tab button is clicked */
    if (lv_event_get_code(e) == LV_EVENT_SCROLL_BEGIN) {
        lv_anim_t* a = lv_event_get_param(e);
        if (a)  a->time = 0;
lv_obj_add_event_cb(lv_tabview_get_content(tabView), scroll_begin_event_cb, LV_EVENT_SCROLL_BEGIN, NULL);
Kind Regards,
Pete
Hi Pete,
I get where you are going with your example.
When you attach the event handler for tabView you forget to send the content.
I have been trying this, but still no success
lv_obj_add_event_cb(tabView, CbScrollBeginEvent, LV_EVENT_SCROLL_BEGIN, lv_tabview_get_content(tabView));
static void CbScrollBeginEvent(lv_event_t* e)
        lv_anim_t* a = (lv_anim_t*)lv_event_get_param(e);
        if (a)
            a->time = 0;
Hi @AlexJ ,
My sincere apologies I should test my code before suggesting it, I made a typo…
Please see this TESTED version:
        if (a)
            a->time = 0;
void tv_example( lv_obj_t *myScreen ) {
	lv_obj_t *tabView = lv_tabview_create(myScreen, LV_DIR_TOP, 30);
	lv_obj_add_event_cb(lv_tabview_get_content(tabView), CbScrollBeginEvent, LV_EVENT_SCROLL_BEGIN, NULL);
	lv_obj_t *tab1 = lv_tabview_add_tab(tabView, "Tab1");
	lv_obj_t *tab2 = lv_tabview_add_tab(tabView, "Tab2");
	lv_obj_t *txt = lv_label_create( tab1 );
	lv_label_set_text( txt, "Text on Tab1" );
	txt = lv_label_create( tab2 );
	lv_label_set_text( txt, "Text on Tab2" );
tv_example( lv_scr_act() );
I hope it’s okay for you now! :slight_smile:
Kind Regards,
Pete
Thanks a lot Pete for your time. It seems to work now :slight_smile:
It still seems a little slow. I guess it would be better just to disable the finger sliding between tabs.
When I use the tab menu the speed is ok.
Is there a way to disable finger sliding totally?
Best regards,
Alex
Hi @AlexJ ,
Sure, see below:
        if (a)
            a->time = 0;
	lv_obj_clear_flag(lv_tabview_get_content(tabView), LV_OBJ_FLAG_SCROLLABLE);
Kind Regards,
Pete
Thanks a lot Pete - you saved my day :smiley:
This eliminated the sluggishness i felt :slight_smile:
Have a nice day.
