I’d need the Arc (of the arc widget) be as large as the parent container allows and be centered horizontally. Since I don’t know how the parent container is large I set the width and height of the Arc widget to LV_PCT(100). This makes the widget as large as possible BUT if it gets more wide than high then the Arc itself is left aligned and I can’t find any way how to center it.
PC Linux
9.2
centering of the Arc inside its own widget.
Flex, grow and many other things, to no avail.
An idea: if it was possible to get the current height of the widget in pixels I could set the width to the same value but at runtime it returns height = 0.
lv_obj_t *container = lv_obj_create(lv_screen_active());
lv_obj_set_size(container, lv_pct(100), lv_pct(100));
lv_obj_center(container);
lv_obj_t* arc = lv_arc_create(container);
lv_obj_set_size(arc, lv_pct(100), lv_pct(100));
lv_obj_center(arc);
lv_obj_set_style_border_width(arc, 1, 0);
Thanks!
