Cant scroll with encder if i have 4 buttons in muy panel. ESP32S3 with monochorm display
Im working on building a UI for a 128 X 64 ssd1206 monochrome display working with an encoder, i´ve successfully added the encoder and made it work with 3 button, my main menu is composed of a container at the top with a label and at some point i will add a battery voltage, wifi rssi and lora rssi( this takes 1/3 of my screen), then on the other 2/3 i have a panel with buttons that i can scroll to select a different menu.
The problem that i have is that it works great with 3 buttons, when i add a 4th button it wont scroll through the menu, when i add 5 button it work great again, when i add 6+ buttons it starts doing strange stuff like changing the encoder direction and skipping buttons but the encoder can scroll.
  • ESP32S3, (Heltek Lora v3.2)
  • EEZ studio for debeloping the UI
  • PlatformIO with arfuino framework
  • Create the panel and buttons my self
  • Use squerline studio to se if it made a diference
Figure out why it doesn’t work with 4 buttons, and start to fail again with 6 + buttons
  • Change flags in the panel and the buttons
  • Instead of using a panel, using a container
  • Change the height of the panel
  • Change
this is the code that EZZ provided.
void create_screen_main_menu() {
    void *flowState = getFlowState(0, 0);
    (void)flowState;
    lv_obj_t *obj = lv_obj_create(0);
    objects.main_menu = obj;
    lv_obj_set_pos(obj, 0, 0);
    lv_obj_set_size(obj, 128, 64);
    lv_obj_add_event_cb(obj, event_handler_cb_main_menu_main_menu, LV_EVENT_ALL, flowState);
    lv_obj_clear_flag(obj, LV_OBJ_FLAG_CLICK_FOCUSABLE);
    lv_obj_set_style_bg_color(obj, lv_color_hex(0xff000000), LV_PART_MAIN | LV_STATE_DEFAULT);
        lv_obj_t *parent_obj = obj;
            // Header
            lv_obj_t *obj = lv_obj_create(parent_obj);
            objects.header = obj;
            lv_obj_set_size(obj, 128, 22);
            lv_obj_set_style_pad_left(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_top(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_right(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_bottom(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_radius(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_clear_flag(obj, LV_OBJ_FLAG_CLICK_FOCUSABLE|LV_OBJ_FLAG_GESTURE_BUBBLE|LV_OBJ_FLAG_PRESS_LOCK|LV_OBJ_FLAG_SCROLLABLE|LV_OBJ_FLAG_SCROLL_CHAIN_HOR|LV_OBJ_FLAG_SCROLL_CHAIN_VER|LV_OBJ_FLAG_SCROLL_ELASTIC|LV_OBJ_FLAG_SCROLL_MOMENTUM|LV_OBJ_FLAG_SCROLL_WITH_ARROW|LV_OBJ_FLAG_SNAPPABLE);
            lv_obj_set_style_border_color(obj, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_border_width(obj, 1, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_border_side(obj, LV_BORDER_SIDE_BOTTOM, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_text_color(obj, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_text_font(obj, &ui_font_pixelade_18, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_opa(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
                    // menuName
                    lv_obj_t *obj = lv_label_create(parent_obj);
                    objects.menu_name = obj;
                    lv_obj_set_pos(obj, 0, -1);
                    lv_obj_set_size(obj, 70, 23);
                    lv_label_set_long_mode(obj, LV_LABEL_LONG_SCROLL_CIRCULAR);
                    lv_label_set_text(obj, "Main Menu");
            // mainmenuPanel
            objects.mainmenu_panel = obj;
            lv_obj_set_pos(obj, 0, 22);
            lv_obj_set_size(obj, 128, 42);
            lv_obj_clear_flag(obj, LV_OBJ_FLAG_CLICKABLE|LV_OBJ_FLAG_CLICK_FOCUSABLE|LV_OBJ_FLAG_GESTURE_BUBBLE|LV_OBJ_FLAG_PRESS_LOCK|LV_OBJ_FLAG_SCROLL_CHAIN_HOR|LV_OBJ_FLAG_SCROLL_ELASTIC|LV_OBJ_FLAG_SCROLL_MOMENTUM|LV_OBJ_FLAG_SCROLL_WITH_ARROW|LV_OBJ_FLAG_SNAPPABLE);
            lv_obj_set_scrollbar_mode(obj, LV_SCROLLBAR_MODE_OFF);
            lv_obj_set_scroll_dir(obj, LV_DIR_VER);
            lv_obj_set_scroll_snap_x(obj, LV_SCROLL_SNAP_CENTER);
            lv_obj_set_scroll_snap_y(obj, LV_SCROLL_SNAP_CENTER);
            lv_obj_set_style_layout(obj, LV_LAYOUT_FLEX, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_flex_flow(obj, LV_FLEX_FLOW_COLUMN, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_flex_main_place(obj, LV_FLEX_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_border_color(obj, lv_color_hex(0xff000000), LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_row(obj, 6, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_flex_grow(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_text_font(obj, &ui_font_pixelade_14, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_border_width(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_flex_track_place(obj, LV_FLEX_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_flex_cross_place(obj, LV_FLEX_ALIGN_START, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_color(obj, lv_color_hex(0xffffffff), LV_PART_SCROLLBAR | LV_STATE_DEFAULT);
                    // wifiButton
                    lv_obj_t *obj = lv_btn_create(parent_obj);
                    objects.wifi_button = obj;
                    lv_obj_set_pos(obj, 42, 14);
                    lv_obj_set_size(obj, 100, 16);
                    lv_obj_clear_flag(obj, LV_OBJ_FLAG_CLICK_FOCUSABLE|LV_OBJ_FLAG_GESTURE_BUBBLE|LV_OBJ_FLAG_PRESS_LOCK|LV_OBJ_FLAG_SCROLL_CHAIN_HOR|LV_OBJ_FLAG_SCROLL_ELASTIC|LV_OBJ_FLAG_SCROLL_MOMENTUM|LV_OBJ_FLAG_SCROLL_WITH_ARROW|LV_OBJ_FLAG_SNAPPABLE);
                    lv_obj_set_scroll_dir(obj, LV_DIR_NONE);
                    lv_obj_set_scroll_snap_y(obj, LV_SCROLL_SNAP_NONE);
                    lv_obj_set_style_radius(obj, 3, LV_PART_MAIN | LV_STATE_DEFAULT);
                    lv_obj_set_style_flex_flow(obj, LV_FLEX_FLOW_ROW, LV_PART_MAIN | LV_STATE_DEFAULT);
                    lv_obj_set_style_pad_column(obj, 10, LV_PART_MAIN | LV_STATE_DEFAULT);
                    lv_obj_set_style_outline_color(obj, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_FOCUS_KEY);
                    lv_obj_set_style_translate_x(obj, -9, LV_PART_MAIN | LV_STATE_FOCUS_KEY);
                    lv_obj_set_style_outline_opa(obj, 255, LV_PART_MAIN | LV_STATE_FOCUS_KEY);
                    lv_obj_set_style_outline_width(obj, 1, LV_PART_MAIN | LV_STATE_FOCUS_KEY);
                    lv_obj_set_style_outline_pad(obj, 3, LV_PART_MAIN | LV_STATE_FOCUS_KEY);
                            // wifiIcon
                            lv_obj_t *obj = lv_img_create(parent_obj);
                            objects.wifi_icon = obj;
                            lv_obj_set_size(obj, 16, 16);
                            lv_img_set_src(obj, &img_wifi);
                            lv_obj_clear_flag(obj, LV_OBJ_FLAG_ADV_HITTEST|LV_OBJ_FLAG_CLICK_FOCUSABLE|LV_OBJ_FLAG_GESTURE_BUBBLE|LV_OBJ_FLAG_PRESS_LOCK|LV_OBJ_FLAG_SCROLLABLE|LV_OBJ_FLAG_SCROLL_CHAIN_HOR|LV_OBJ_FLAG_SCROLL_CHAIN_VER|LV_OBJ_FLAG_SCROLL_ELASTIC|LV_OBJ_FLAG_SCROLL_MOMENTUM|LV_OBJ_FLAG_SCROLL_WITH_ARROW|LV_OBJ_FLAG_SNAPPABLE);
                            lv_obj_set_style_img_recolor_opa(obj, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
                            lv_obj_set_style_img_recolor(obj, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_DEFAULT);
                            // wifiLabel
                            objects.wifi_label = obj;
                            lv_obj_set_size(obj, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
                            lv_obj_set_style_align(obj, LV_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
                            lv_label_set_text(obj, "Wifi");
                    // loraButton
                    objects.lora_button = obj;
                            // loraIcon
                            objects.lora_icon = obj;
                            lv_img_set_src(obj, &img_lora2);
                            lv_img_set_zoom(obj, 200);
                            // loraLabel
                            objects.lora_label = obj;
                            lv_label_set_text(obj, "LoRa");
                    // settingsButton
                    objects.settings_button = obj;
                            // settingsIcon
                            objects.settings_icon = obj;
                            lv_img_set_src(obj, &img_settings);
                            // settingsLabel
                            objects.settings_label = obj;
                            lv_label_set_text(obj, "Settings");
    tick_screen_main_menu();
This is my display flush function. im ussing a double buffer
void display_flush(lv_disp_drv_t * disp_drv,const lv_area_t * area, lv_color_t *color_p){
    for (int y = area->y1; y <= area->y2; y++) {
        for (int x = area->x1; x <= area->x2; x++) {
            // Convert LVGL color to SSD1306 monochrome
            bool pixel_on = (color_p->full != 0);
            display.drawPixel(x, y, pixel_on);
            color_p++;
    display.display();
And my init disply Function
void init_display(){
     //Turn on vext so display is powered by usbc
     vext_ON();
     //initialize i2c comunication with custom sda and scl pins
     Wire.begin(SDA_OLED,SCL_OLED);
     Wire.setClock(400000); // 400kHz I2C
     //Initialize display and error if it doesent
     if(!display.begin(SSD1306_SWITCHCAPVCC,0x3C)){
         Serial.println("Diplay init Faild");
         while(true);
     display.invertDisplay(false);
     display.setRotation(0); // Ensure native orientation
     display.dim(false); // Ensure full brightness
     display.clearDisplay();
     display.display();
     //Initialize lvgl
    //Set up LVGL display buffer (Small buf for SSD1306)
    static lv_color_t buf1[SCREEN_WIDTH * 100]; // First buffer
    static lv_color_t buf2[SCREEN_WIDTH * 100]; // Second buffer
    lv_disp_draw_buf_init(&draw_buf,buf1,NULL,SCREEN_WIDTH * 100);
    //Register display drivers
    lv_disp_drv_init(&disp_drv);
    disp_drv.hor_res = SCREEN_WIDTH;
    disp_drv.ver_res = SCREEN_HEIGHT;
    disp_drv.flush_cb = display_flush;
Found my error, my encoder had a *4 sensitivity increase and my diff output was 4 the problem was that the encoder could not scroll through the menu because it was doing a 4 step jump, so it was nos able to select anything in the menu.
