Hi all, I have just started using Squareline and LVGL and failing at just updating the screen every 500ms to increment an arc/silder. not sure what im missing but I have the screen displaying the initial image(below) and not doing anything else. I know the program isnt frozen as I output via serial which still works.
Chipset: ESP32-S3 (FN8) (Custom Board)
LVGL version: 8.3.6
Task: I want to move an arc by 1 every 500ms and reset back to 1 at 100.
So Far Achieved: I have used the simple demo ui from Squareline and adjusted some minor bits.
Code to reproduce:
#include <Arduino.h>
#include <TFT_eSPI.h>
#include <SPI.h>
#define USE_UI //if you want to use the ui export from Squareline ,pleease define USE_UI.
#include <lvgl.h>
#include "ui.h"
static const uint16_t screenWidth = 240;
static const uint16_t screenHeight = 320;
TFT_eSPI lcd = TFT_eSPI(); /* TFT entity */
static lv_color_t buf1[ screenWidth * screenHeight / 13 ];
//_______________________
/* display flash */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
lcd.startWrite();
lcd.setAddrWindow( area->x1, area->y1, w, h );
lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
lcd.endWrite();
lv_disp_flush_ready( disp );
void setup()
Serial.begin( 115200 ); /*serial init */
delay(2000);
//LCD init
lcd.begin();
lcd.setRotation(2);
lcd.fillScreen(TFT_BLACK);
delay(100);
//background light pin
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
//lvgl init
lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 13 );
/*Display init*/
/*Display driver port of LVGL*/
lv_disp_drv_register( &disp_drv );
ui_init(); //LVGL UI init
void loop()
static int16_t counter = 1;
counter++;
lv_arc_set_value(ui_Arc1, counter);
lv_event_send(ui_Arc1, LV_EVENT_VALUE_CHANGED, 0);
counter %=100;
delay(500);
Serial.println(".");
lv_timer_handler();
