Can’t get LVGL 9.0 running in Arduino
Raspberry Pi Pico, ESP32
Using 3.6.3 version of Arduino-Pico and latest stable of arduino-esp32
9.0.0, installed via Arduino Library Manager
Successfully running the LVGL 9.0 version of the LVGL_Arduino sketch
Successfully tested TFT_eSPI on both platforms (both using ILI9341 display in SPI mode)
Set up lv_conf.h to enable its inclusion and enable TFT_eSPI
Compile LVGL_Arduino sketch for both platforms (no errors)
No examples or demos are enabled, only the code that should show the label in LVGL_Arduino
When I upload the code to either platform, nothing appears on the screen. The Pico locks up so that the serial port is no longer available and I have to depower and use the bootsel button to get it back into UF2 mode.
The same hardware and TFT_eSPI configurations were working with the LVGL_Arduino script included with LVGL 8.3.11.
