i everybody,
I’m trying to apply a style but it doesn’t work… What did I do wrong??
this is my code:
//style def
static lv_style_t* stylTitle;
lv_style_init(stylTitle);
//define the text and apply style
lv_style_set_text_font(stylTitle,LV_FONT_MONTSERRAT_10);
lv_label_set_text(label, BoatName.c_str()); // set label text
lv_obj_add_style(label,stylTitle,0);
lv_obj_align(label, LV_ALIGN_TOP_MID, 0, 20); // Center but 20 from the top
Without style, everything works fine, with style, the display is blinking white (nothing on it, just white blinking)
Display :WT32-SC01_V3.3
ESP32 Wronder (programmed as Expressif ESP32 DEVmodule
LVGL V8.3.11
IDE VS-platformIO
I’ve tried this but can’t compile in LVGL V8.3.11??
LV_STATE_DEFAULT,&LV_FONT_MONTSERRAT_10 is not correct for the compiler. the function lv_style_set_text_font() seems to have only 2 arguments and not 3…
I’m stuck on character sizes since yesterday.:-(everything is working fine if I use lcd.setTextSize(3) and lcd.println() but it’s not a proper way to do it…
Thank you for your help.
Hi Tinus,
Thank you for your time and your answer…
Unfortunately, it doesn’t work (I’ve tried before and try again) but same result.
//style def
static lv_style_t stylTitle;
lv_style_init(&stylTitle);
lv_style_set_text_font(&stylTitle,LV_FONT_MONTSERRAT_10);
lv_obj_t *label = lv_label_create(lv_scr_act()); // full screen as the parent
lv_obj_add_style(label,&stylTitle,0);
give exactly the same result. full white blinking display…
This is working but can’t increase the title:
//style def
//static lv_style_t stylTitle;
//lv_style_init(&stylTitle);
//lv_style_set_text_font(&stylTitle,LV_FONT_MONTSERRAT_10);
//lv_obj_add_style(label,&stylTitle,0);
I probably did something wrong but I can’t ffind what
and &LV_FONT_MONTSERRAT_10 doesn’t compile
If you have another idea, just let me know and I will try again.
Thank you Tinus.
Hi Trident,
Thank you for your time and your answer.
Unfortunately, lv_style_set_text_font(&stylTitle,&lv_font_montserrat_10);
doesn’t compile neither…
The error is:
src/main.cpp:80:38: error: ‘lv_font_montserrat_10’ was not declared in this scope
in the library, the font are declared in block letters so, it doesn’t work and this is not a surprise but I tried anyway…
lv_style_set_text_font(&stylTitle,&lv_font_montserrat_26);
You was right, in lower case with &…
Thank you so much Trident. and yes, need to modify the lv_conf.h.
I would like that the label “60” be filling up the whole button, however this does not happen… it compiles fine, since I appropriately enabled the lv_conf.h, however the result is a button with the label of unchanged size
