I would like to add userdata to the event. However, the user data is always transmitted incorrectly.
Arduino Due / Arduino IDE
V8.0
The user data correctly transferred to the event callback function
I tried to transfer user data via LVGL functions. When reading out the data does not match the original data that I sent. I send an Integer like 10001 but when i print the receive userdata it is something like 5344554.
int tmp_numpad_userdata;
tmp_numpad_userdata = channel * 10000 + current_frame * 100 + current_signal;
lv_obj_add_event_cb(labelReihe1[current_signal + output_config_send_data_offset][1], my_event_cb_NUM_Pad, LV_EVENT_CLICKED, &tmp_numpad_userdata);
// and the cb function
static void my_event_cb_NUM_Pad(lv_event_t * e)
int * userdata = (int *)lv_event_get_user_data(e);
//int userdata2 = int(*userdata)
//int *pInt = static_cast<int*>(lv_event_get_user_data(e));
log_newline();
log_item("Übergabeparameter ist ");
log_item(* userdata);
log_newline();
