Cannot Get Touch to register in my code
I have no idea what to do and my_touchpad_read() looks like not called at all (Code copied bellow).
I Use XPT2046_Touchscreen libary made by Paul Stoffregen and Adafruit GFX(ILI9381) for writing the buffer because i had issues with TFT_eSPI.
I like to work with real humans instead of some AI slop-nonsense.
Arduino IDE 1.8x , LVGL v8.4.0 , ESP32S3 Dev Module
/*Using LVGL with Arduino requires some extra steps:
 *Be sure to read the docs here: https://docs.lvgl.io/master/get-started/platforms/arduino.html  */
#include <lvgl.h>
#include <Adafruit_ILI9341.h>
#include <XPT2046_Touchscreen.h>
/*To use the built-in examples and demos of LVGL uncomment the includes below respectively.
 *You also need to copy `lvgl/examples` to `lvgl/src/examples`. Similarly for the demos `lvgl/demos` to `lvgl/src/demos`.
 Note that the `lv_examples` library is for LVGL v7 and you shouldn't install it for this version (since LVGL v8)
 as the examples and demos are now part of the main LVGL library. */
/*Change to your screen resolution*/
static const uint16_t screenWidth  = 320;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
#define TIRQ_PIN  7
#define CS_PIN    8
#define TFT_DC    9
#define TFT_CS    10
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
XPT2046_Touchscreen ts(CS_PIN);  // Param 2 - Touch IRQ Pin - interrupt enabled polling
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
    Serial.printf(buf);
    Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p )
    uint32_t w = ( area->x2 - area->x1 + 1 );
    uint32_t h = ( area->y2 - area->y1 + 1 );
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.writePixels( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    lv_disp_flush_ready( disp_drv );
static void event_handler(lv_event_t * e)
        LV_LOG_USER("Clicked");
    else if(code == LV_EVENT_VALUE_CHANGED) {
        LV_LOG_USER("Toggled");
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_drv, lv_indev_data_t * data )
    uint16_t touchX, touchY;
    TS_Point touch = ts.getPoint();
    if( ts.touched() )
        touchX = touch.x;
        touchY = touch.y;
        /*Set the coordinates*/
        data->point.x = touchX;
        data->point.y = touchY;
        Serial.print( "Data x " );
        Serial.println( touchX );
        Serial.print( "Data y " );
        Serial.println( touchY );
void setup()
    Serial.begin( 115200 ); /* prepare for possible serial debug */
    LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
    Serial.println( LVGL_Arduino );
    Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
    lv_log_register_print_cb( my_print ); /* register print function for debugging */
    tft.begin();          /* TFT init */
    tft.setRotation( 3 ); /* Landscape orientation, flipped */
    tft.fillScreen( ILI9341_BLACK );
    ts.begin();
    /*Set the touchscreen calibration data,
     the actual data for your display can be acquired using
     the Generic -> Touch_calibrate example from the TFT_eSPI library*/
    uint16_t calData[5] = { 275, 3620, 264, 3532, 1 };
    //tft.setTouch( calData );
    lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
    /*Initialize the display*/
    /*Change the following line to your display resolution*/
    lv_disp_drv_register( &disp_drv );
    lv_indev_drv_register( &indev_drv );
    /* Create simple label
    lv_obj_t *label = lv_label_create( lv_scr_act() );
    lv_label_set_text( label, "Hello Ardino and LVGL!");
    lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
    /* Try an example. See all the examples
     * online: https://docs.lvgl.io/master/examples.html
     * source codes: https://github.com/lvgl/lvgl/tree/e7f88efa5853128bf871dde335c0ca8da9eb7731/examples */
     //lv_example_btn_1();
     /*Or try out a demo. Don't forget to enable the demos in lv_conf.h. E.g. LV_USE_DEMOS_WIDGETS*/
    //lv_demo_widgets();
    // lv_demo_benchmark();
    // lv_demo_keypad_encoder();
    // lv_demo_music();
    // lv_demo_printer();
    // lv_demo_stress();
    lv_obj_t * label;
    lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn1, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -40);
    label = lv_label_create(btn1);
    lv_obj_center(label);
    lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn2, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn2, LV_ALIGN_CENTER, 0, 40);
    lv_obj_add_flag(btn2, LV_OBJ_FLAG_CHECKABLE);
    lv_obj_set_height(btn2, LV_SIZE_CONTENT);
    label = lv_label_create(btn2);
    lv_label_set_text(label, "Toggle");
void loop()
I fixed it by adding:
the code i shared up is debugging code btw, so it is kinda botched to see what it does.
void loop()
    delay(5);
    lv_tick_inc(5); //here
Hello, first off, nice profile picture.
The idea is that lv_tick_inc(x) is called in a timer interrupt where you can be sure it occurs every x milliseconds. lv_timer_handler() should be called in your main loop.
This implementation is a bit strange and not really the intended way to use these functions.
