Hello, I’m having an issue with the lv_table widget. I cannot get it to scroll the table off screen.
I’m using an embedded board , RPI PICO 2040, EEZ Studio LVGL project, VS Code LVGL 8.3. My LCD is 240 x 240 px, aprox 1.5" square.
I ported over the exact code from the Simple table example Table (lv_table) — LVGL documentation
I am using hardware keys, with user actions to send up/down/enter arrow key events to the table object. The object receives the keys.
The screen will show the selected cell up and down the list. I added some code in the draw_part_event cb() to highlight the selected cell. and I confirmed the row, column values were correct.
The example code was using a default font so everything was very small and the entire table fit on the screen so scrolling was not occurring.
I changed to a larger font that I was already using on my application, and changed to use only a single column table. This allowed about 4 cells to be displayed on the screen. And I tried to see if the scrolling would work.
When I reached the bottom of the screen it would not scroll. Instead each pressing of the down key just incremented the row and the highlight off the screen. Pressing the up key would move the highlight back on to screen.
At no time did the scroll bar move.
I literally tried every parameter in the lvgl scrolling and lv_table LVGL documentation.
I even tried turning on the Scrollable flags for the parent screen object of the table. It displayed scroll bars but had no effect.
I’ve included the relevant code and screen shots of my screen for the Table test . I would appreciate any ideas.
<screens.c>
static void draw_part_event_cb(lv_event_t * e)
/*If the cells are drawn...*/
if(dsc->part == LV_PART_ITEMS) {
uint32_t row = dsc->id / lv_table_get_col_cnt(obj);
uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
/*Make the texts in the first cell center aligned*/
if(row == 0) {
dsc->label_dsc->align = LV_TEXT_ALIGN_CENTER;
dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_BLUE), dsc->rect_dsc->bg_color, LV_OPA_20);
dsc->rect_dsc->bg_opa = LV_OPA_COVER;
/*In the first column align the texts to the right*/
else if(col == 0) {
/*MAke every 2nd row blueish*/
if((row != 0 && row % 2) == 0) {
dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_BLUE), dsc->rect_dsc->bg_color, LV_OPA_90);
uint16_t sel_col;
uint16_t sel_row;
lv_table_get_selected_cell(obj, &sel_row, &sel_col);
/*update color of row selectd*/
if(sel_row == row && sel_col == col) {
dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_YELLOW), dsc->rect_dsc->bg_color, LV_OPA_90);
void create_screen_table_test() {
void *flowState = getFlowState(0, 15);
lv_obj_t *obj = lv_obj_create(0);
objects.table_test = obj;
lv_obj_set_pos(obj, 0, 0);
lv_obj_set_size(obj, 240, 240);
lv_obj_add_event_cb(obj, event_handler_cb_table_test_table_test, LV_EVENT_ALL, flowState);
lv_obj_clear_flag(obj, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_set_style_bg_color(obj, lv_color_hex(0xfff2f2f2), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_t *parent_obj = obj;
// table
lv_obj_t *obj = lv_table_create(parent_obj);
objects.table = obj;
lv_obj_set_size(obj, 240, 480);
//lv_obj_add_flag(objects.table, LV_OBJ_FLAG_SCROLLABLE);
//lv_obj_add_flag(objects.table, LV_OBJ_FLAG_SCROLL_ON_FOCUS);
//lv_obj_set_scrollbar_mode(objects.table, LV_SCROLLBAR_MODE_AUTO);
//lv_obj_set_scroll_dir(objects.table, LV_DIR_VER);
//lv_table_set_col_cnt(objects.table, 1);
lv_table_set_col_width(objects.table, 0, 238);
//lv_table_set_row_cnt(objects.table, 8);
lv_obj_set_style_text_font(objects.table, &ui_font_dosis_reg_36, LV_PART_MAIN | LV_STATE_DEFAULT);
// Ent_button_cloaked_5
lv_obj_t *obj = lv_btn_create(parent_obj);
objects.ent_button_cloaked_5 = obj;
lv_obj_set_pos(obj, 262, -30);
lv_obj_set_size(obj, 1, 1);
lv_obj_add_event_cb(obj, event_handler_cb_table_test_ent_button_cloaked_5, LV_EVENT_ALL, flowState);
lv_obj_clear_flag(obj, LV_OBJ_FLAG_CLICK_FOCUSABLE);
lv_obj_set_style_border_color(obj, lv_color_hex(0xfff2f2f2), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_width(obj, 1, LV_PART_MAIN | LV_STATE_DEFAULT);
// Dwn_button_cloaked_6
objects.dwn_button_cloaked_6 = obj;
lv_obj_set_pos(obj, -300, -40);
lv_obj_add_event_cb(obj, event_handler_cb_table_test_dwn_button_cloaked_6, LV_EVENT_ALL, flowState);
// Up_button_cloaked_2
objects.up_button_cloaked_2 = obj;
lv_obj_set_pos(obj, 200, 275);
lv_obj_add_event_cb(obj, event_handler_cb_table_test_up_button_cloaked_2, LV_EVENT_ALL, flowState);
/*Fill the first column*/
lv_table_set_cell_value(objects.table, 0, 0, "Name");
lv_table_set_cell_value(objects.table, 1, 0, "Apple");
lv_table_set_cell_value(objects.table, 2, 0, "Banana");
lv_table_set_cell_value(objects.table, 3, 0, "Lemon");
lv_table_set_cell_value(objects.table, 4, 0, "Grape");
lv_table_set_cell_value(objects.table, 5, 0, "Melon");
lv_table_set_cell_value(objects.table, 6, 0, "Peach");
lv_table_set_cell_value(objects.table, 7, 0, "Nuts");
/*Set a smaller height to the table. It'll make it scrollable*/
lv_obj_set_height(objects.table, 240);
lv_obj_center(objects.table);
/*Fill the second column*/
// lv_table_set_cell_value(objects.table, 0, 1, "Price");
// lv_table_set_cell_value(objects.table, 1, 1, "$7");
// lv_table_set_cell_value(objects.table, 2, 1, "$4");
// lv_table_set_cell_value(objects.table, 3, 1, "$6");
// lv_table_set_cell_value(objects.table, 4, 1, "$2");
// lv_table_set_cell_value(objects.table, 5, 1, "$5");
// lv_table_set_cell_value(objects.table, 6, 1, "$1");
// lv_table_set_cell_value(objects.table, 7, 1, "$9");
/*Add an event callback to to apply some custom drawing*/
//lv_obj_add_event_cb(objects.table, change_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_add_event_cb(objects.table, draw_part_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
// actions.c - user actions code to send the key events to the widget
void action_send_enterkey_to_table(lv_event_t *e) {
uint32_t t = LV_KEY_ENTER;
lv_event_send(objects.table, LV_EVENT_KEY, &t);
void action_send_dwnkey_to_table(lv_event_t *e) {
uint32_t t = LV_KEY_DOWN;
void action_send_upkey_to_table(lv_event_t *e) {
uint32_t t = LV_KEY_UP;
