Cannot get past lv_timer_handler() on STM32h563
I made a custom STM32H563 board and am trying to get LVGL working on a basic ST7789 LCD. I can get a blink sketch going but am having trouble displaying anything.
I’m using a STM32H563 with X-CUBE-FREERTOS
LVGL v9.3.0
I used this guide as a base: Step-by-step Guide: How to use the LVGL v9 LCD drivers with STM32 devices — LVGL documentation
Problem:
It seems to run and communicate fine with the LCD and I get that “static” image that you would normally see on a ST7789 right before it would display an image but then it freezes. Nothing executes after “lv_timer_handler();” is called in the task loop. From what I can tell, it’s getting stuck on while(disp->flushing); in lvgl_refr.c and I cannot determine why. Any help is appreciated! Here is the full code:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "cmsis_os2.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "lvgl.h"
#include "./src/drivers/display/st7789/lv_st7789.h"
#include <stdio.h>
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define LCD_H_RES       240
#define LCD_V_RES       320
#define BUS_SPI1_POLL_TIMEOUT 0x1000U
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
const osThreadAttr_t lvglTask_attributes = {
    .name = "LVGL_Task",
    .priority = osPriorityNormal,
    .stack_size = 1024 * 16 // Stack size in bytes
const osThreadAttr_t blinkTask_attributes = {
    .name = "Blink_Task",
    .priority = osPriorityIdle,
    .stack_size = 1024 // 128 without printf
/* USER CODE END PM */
ADC_HandleTypeDef hadc1;
ADC_HandleTypeDef hadc2;
I2C_HandleTypeDef hi2c1;
I2C_HandleTypeDef hi2c4;
SPI_HandleTypeDef hspi1;
SPI_HandleTypeDef hspi2;
SPI_HandleTypeDef hspi3;
DMA_HandleTypeDef handle_GPDMA1_Channel7;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
osThreadId_t BlinkTaskHandle;
osThreadId_t LvglTaskHandle;
lv_display_t *lcd_disp;
volatile int lcd_bus_busy = 0;
/* USER CODE END PV */
void SystemClock_Config(void);
void MX_FREERTOS_Init(void);
static void MX_GPDMA1_Init(void);
static void MX_ICACHE_Init(void);
static void MX_I2C1_Init(void);
static void MX_SPI1_Init(void);
static void MX_SPI2_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_ADC1_Init(void);
static void MX_I2C4_Init(void);
static void MX_ADC2_Init(void);
static void MX_SPI3_Init(void);
/* USER CODE BEGIN PFP */
void ui_init(lv_display_t *disp);
void LVGL_Task(void *argument);
void Blink_Task(void *argument);
void lcd_color_transfer_ready_cb(SPI_HandleTypeDef *hspi);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
int _write(int file, char *ptr, int len) // enable printf() debugging
  (void)file;
  int DataIdx;
  for (DataIdx = 0; DataIdx < len; DataIdx++)
    //__io_putchar(*ptr++);
	  ITM_SendChar(*ptr++);
  return len;
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_GPDMA1_Init();
  MX_ICACHE_Init();
  MX_I2C1_Init();
  MX_SPI1_Init();
  MX_SPI2_Init();
  MX_USART1_UART_Init();
  MX_ADC1_Init();
  MX_I2C4_Init();
  MX_ADC2_Init();
  MX_SPI3_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Init scheduler */
  osKernelInitialize();
  /* Call init function for freertos objects (in cmsis_os2.c) */
  BlinkTaskHandle = osThreadNew(Blink_Task, NULL, &blinkTask_attributes);
  LvglTaskHandle = osThreadNew(LVGL_Task, NULL, &lvglTask_attributes); // FreeRTOS total heap size changed to ((size_t)(20 * 1024))
  if (LvglTaskHandle == NULL) {
      printf("LVGL_Task creation failed\n");
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLL1_SOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 62;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1_VCIRANGE_3;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1_VCORANGE_WIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 4096;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_PCLK3;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  /** Configure the programming delay
  __HAL_FLASH_SET_PROGRAM_DELAY(FLASH_PROGRAMMING_DELAY_2);
  * @brief ADC1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC1_Init 1 */
  /* USER CODE END ADC1_Init 1 */
  /** Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.SamplingMode = ADC_SAMPLING_MODE_NORMAL;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN ADC1_Init 2 */
  /* USER CODE END ADC1_Init 2 */
  * @brief ADC2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN ADC2_Init 0 */
  /* USER CODE END ADC2_Init 0 */
  /* USER CODE BEGIN ADC2_Init 1 */
  /* USER CODE END ADC2_Init 1 */
  /** Common config
  hadc2.Instance = ADC2;
  hadc2.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc2.Init.Resolution = ADC_RESOLUTION_12B;
  hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc2.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc2.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc2.Init.LowPowerAutoWait = DISABLE;
  hadc2.Init.ContinuousConvMode = DISABLE;
  hadc2.Init.NbrOfConversion = 1;
  hadc2.Init.DiscontinuousConvMode = DISABLE;
  hadc2.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc2.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc2.Init.DMAContinuousRequests = DISABLE;
  hadc2.Init.SamplingMode = ADC_SAMPLING_MODE_NORMAL;
  hadc2.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc2.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc2) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_13;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc2, &sConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN ADC2_Init 2 */
  /* USER CODE END ADC2_Init 2 */
  * @brief GPDMA1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN GPDMA1_Init 0 */
  /* USER CODE END GPDMA1_Init 0 */
  /* Peripheral clock enable */
  __HAL_RCC_GPDMA1_CLK_ENABLE();
  /* GPDMA1 interrupt Init */
    HAL_NVIC_SetPriority(GPDMA1_Channel7_IRQn, 5, 0);
    HAL_NVIC_EnableIRQ(GPDMA1_Channel7_IRQn);
  /* USER CODE BEGIN GPDMA1_Init 1 */
  /* USER CODE END GPDMA1_Init 1 */
  /* USER CODE BEGIN GPDMA1_Init 2 */
  /* USER CODE END GPDMA1_Init 2 */
  * @brief I2C1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN I2C1_Init 0 */
  /* USER CODE END I2C1_Init 0 */
  /* USER CODE BEGIN I2C1_Init 1 */
  /* USER CODE END I2C1_Init 1 */
  hi2c1.Instance = I2C1;
  hi2c1.Init.Timing = 0x60808CD3;
  hi2c1.Init.OwnAddress1 = 0;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c1) != HAL_OK)
    Error_Handler();
  /** Configure Analogue filter
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    Error_Handler();
  /** Configure Digital filter
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2C1_Init 2 */
  /* USER CODE END I2C1_Init 2 */
  * @brief I2C4 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN I2C4_Init 0 */
  /* USER CODE END I2C4_Init 0 */
  /* USER CODE BEGIN I2C4_Init 1 */
  /* USER CODE END I2C4_Init 1 */
  hi2c4.Instance = I2C4;
  hi2c4.Init.Timing = 0x60808CD3;
  hi2c4.Init.OwnAddress1 = 0;
  hi2c4.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c4.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c4.Init.OwnAddress2 = 0;
  hi2c4.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c4.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c4.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c4) != HAL_OK)
    Error_Handler();
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c4, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    Error_Handler();
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c4, 0) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2C4_Init 2 */
  /* USER CODE END I2C4_Init 2 */
  * @brief ICACHE Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN ICACHE_Init 0 */
  /* USER CODE END ICACHE_Init 0 */
  /* USER CODE BEGIN ICACHE_Init 1 */
  /* USER CODE END ICACHE_Init 1 */
  /** Enable instruction cache (default 2-ways set associative cache)
  if (HAL_ICACHE_Enable() != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN ICACHE_Init 2 */
  /* USER CODE END ICACHE_Init 2 */
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES_TXONLY;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 0x7;
  hspi1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
  hspi1.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
  hspi1.Init.FifoThreshold = SPI_FIFO_THRESHOLD_01DATA;
  hspi1.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE;
  hspi1.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_00CYCLE;
  hspi1.Init.MasterReceiverAutoSusp = SPI_MASTER_RX_AUTOSUSP_DISABLE;
  hspi1.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_DISABLE;
  hspi1.Init.IOSwap = SPI_IO_SWAP_DISABLE;
  hspi1.Init.ReadyMasterManagement = SPI_RDY_MASTER_MANAGEMENT_INTERNALLY;
  hspi1.Init.ReadyPolarity = SPI_RDY_POLARITY_HIGH;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief SPI2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI2_Init 0 */
  /* USER CODE END SPI2_Init 0 */
  /* USER CODE BEGIN SPI2_Init 1 */
  /* USER CODE END SPI2_Init 1 */
  /* SPI2 parameter configuration*/
  hspi2.Instance = SPI2;
  hspi2.Init.Mode = SPI_MODE_MASTER;
  hspi2.Init.Direction = SPI_DIRECTION_2LINES;
  hspi2.Init.DataSize = SPI_DATASIZE_4BIT;
  hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi2.Init.NSS = SPI_NSS_SOFT;
  hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi2.Init.CRCPolynomial = 0x7;
  hspi2.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  hspi2.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
  hspi2.Init.FifoThreshold = SPI_FIFO_THRESHOLD_01DATA;
  hspi2.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE;
  hspi2.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_00CYCLE;
  hspi2.Init.MasterReceiverAutoSusp = SPI_MASTER_RX_AUTOSUSP_DISABLE;
  hspi2.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_DISABLE;
  hspi2.Init.IOSwap = SPI_IO_SWAP_DISABLE;
  hspi2.Init.ReadyMasterManagement = SPI_RDY_MASTER_MANAGEMENT_INTERNALLY;
  hspi2.Init.ReadyPolarity = SPI_RDY_POLARITY_HIGH;
  if (HAL_SPI_Init(&hspi2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI2_Init 2 */
  /* USER CODE END SPI2_Init 2 */
  * @brief SPI3 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI3_Init 0 */
  /* USER CODE END SPI3_Init 0 */
  /* USER CODE BEGIN SPI3_Init 1 */
  /* USER CODE END SPI3_Init 1 */
  /* SPI3 parameter configuration*/
  hspi3.Instance = SPI3;
  hspi3.Init.Mode = SPI_MODE_MASTER;
  hspi3.Init.Direction = SPI_DIRECTION_2LINES;
  hspi3.Init.DataSize = SPI_DATASIZE_4BIT;
  hspi3.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi3.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi3.Init.NSS = SPI_NSS_SOFT;
  hspi3.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
  hspi3.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi3.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi3.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi3.Init.CRCPolynomial = 0x7;
  hspi3.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  hspi3.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
  hspi3.Init.FifoThreshold = SPI_FIFO_THRESHOLD_01DATA;
  hspi3.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE;
  hspi3.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_00CYCLE;
  hspi3.Init.MasterReceiverAutoSusp = SPI_MASTER_RX_AUTOSUSP_DISABLE;
  hspi3.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_DISABLE;
  hspi3.Init.IOSwap = SPI_IO_SWAP_DISABLE;
  hspi3.Init.ReadyMasterManagement = SPI_RDY_MASTER_MANAGEMENT_INTERNALLY;
  hspi3.Init.ReadyPolarity = SPI_RDY_POLARITY_HIGH;
  if (HAL_SPI_Init(&hspi3) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI3_Init 2 */
  /* USER CODE END SPI3_Init 2 */
  * @brief USART1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&huart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&huart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
  * @param None
  * @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, WL_STOP_WAKE_Pin|WL_DEEP_WAKE_Pin|ANT_SW_Pin|GPIO_PIN_12, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(SPI1_CS_GPIO_Port, SPI1_CS_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, LCD_DC_Pin|LCD_RST_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(LCD_BL_GPIO_Port, LCD_BL_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(GPIOB, SX_NRST_Pin|BUSY_Pin|SPI2_CS_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, BME_ADR_Pin|BMI_ADR_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOD, SPI3_CS_Pin|BLINK_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : WL_STOP_WAKE_Pin WL_DEEP_WAKE_Pin ANT_SW_Pin PE12 */
  GPIO_InitStruct.Pin = WL_STOP_WAKE_Pin|WL_DEEP_WAKE_Pin|ANT_SW_Pin|GPIO_PIN_12;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : STOP_WAKE_Pin IRQ_Pin */
  GPIO_InitStruct.Pin = STOP_WAKE_Pin|IRQ_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pin : SPI1_CS_Pin */
  GPIO_InitStruct.Pin = SPI1_CS_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  HAL_GPIO_Init(SPI1_CS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LCD_DC_Pin */
  GPIO_InitStruct.Pin = LCD_DC_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(LCD_DC_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LCD_RST_Pin */
  GPIO_InitStruct.Pin = LCD_RST_Pin;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  HAL_GPIO_Init(LCD_RST_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : LCD_BL_Pin SX_NRST_Pin BUSY_Pin */
  GPIO_InitStruct.Pin = LCD_BL_Pin|SX_NRST_Pin|BUSY_Pin;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /*Configure GPIO pins : DIO1_Pin DIO2_Pin DIO3_Pin */
  GPIO_InitStruct.Pin = DIO1_Pin|DIO2_Pin|DIO3_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  /*Configure GPIO pin : SPI2_CS_Pin */
  GPIO_InitStruct.Pin = SPI2_CS_Pin;
  HAL_GPIO_Init(SPI2_CS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : BMI_INT2_Pin */
  GPIO_InitStruct.Pin = BMI_INT2_Pin;
  HAL_GPIO_Init(BMI_INT2_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : BMI_INT1_Pin */
  GPIO_InitStruct.Pin = BMI_INT1_Pin;
  HAL_GPIO_Init(BMI_INT1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : BME_ADR_Pin BMI_ADR_Pin */
  GPIO_InitStruct.Pin = BME_ADR_Pin|BMI_ADR_Pin;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : MAIN_BTN_Pin */
  GPIO_InitStruct.Pin = MAIN_BTN_Pin;
  HAL_GPIO_Init(MAIN_BTN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : SPI3_CS_Pin BLINK_Pin */
  GPIO_InitStruct.Pin = SPI3_CS_Pin|BLINK_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
        /* CS high */
        HAL_GPIO_WritePin(SPI1_CS_GPIO_Port, SPI1_CS_Pin, GPIO_PIN_SET);
        lcd_bus_busy = 0;
        lv_display_flush_ready(lcd_disp);
/* Initialize LCD I/O bus, reset LCD */
static int32_t lcd_io_init(void)
        /* Register SPI Tx Complete Callback */
        if (HAL_SPI_RegisterCallback(&hspi1, HAL_SPI_TX_COMPLETE_CB_ID, lcd_color_transfer_ready_cb) != HAL_OK)
        	printf("SPI register callback failed\n");
        /* reset LCD */
        HAL_GPIO_WritePin(LCD_RST_GPIO_Port, LCD_RST_Pin, GPIO_PIN_RESET);
        osDelay(100);
        HAL_GPIO_WritePin(LCD_RST_GPIO_Port, LCD_RST_Pin, GPIO_PIN_SET);
        osDelay(100);
        HAL_GPIO_WritePin(LCD_DC_GPIO_Port, LCD_DC_Pin, GPIO_PIN_SET);
        return HAL_OK;
/* Platform-specific implementation of the LCD send command function. In general this should use polling transfer. */
static void lcd_send_cmd(lv_display_t *disp, const uint8_t *cmd, size_t cmd_size, const uint8_t *param, size_t param_size)
        LV_UNUSED(disp);
        while (lcd_bus_busy);   /* wait until previous transfer is finished */
        /* Set the SPI in 8-bit mode */
        if (HAL_SPI_Init(&hspi1) != HAL_OK) {
            printf("SPI initialization failed\n");
        /* DCX low (command) */
        HAL_GPIO_WritePin(LCD_DC_GPIO_Port, LCD_DC_Pin, GPIO_PIN_RESET);
        /* CS low */
        /* send command */
        if (HAL_SPI_Transmit(&hspi1, cmd, cmd_size, BUS_SPI1_POLL_TIMEOUT) == HAL_OK) {
                /* DCX high (data) */
                /* for short data blocks we use polling transfer */
                HAL_SPI_Transmit(&hspi1, (uint8_t *)param, (uint16_t)param_size, BUS_SPI1_POLL_TIMEOUT);
                /* CS high */
        	printf("SPI transmit failed\n");
/* Platform-specific implementation of the LCD send color function. For better performance this should use DMA transfer.
 * In case of a DMA transfer a callback must be installed to notify LVGL about the end of the transfer.
static void lcd_send_color(lv_display_t *disp, const uint8_t *cmd, size_t cmd_size, uint8_t *param, size_t param_size)
        LV_UNUSED(disp);
        HAL_SPI_Init(&hspi1);
        /* CS low */
        /* send command */
                /* for color data use DMA transfer */
                /* Set the SPI in 16-bit mode to match endianness */
                hspi1.Init.DataSize = SPI_DATASIZE_16BIT;
                lcd_bus_busy = 1;
                HAL_SPI_Transmit_DMA(&hspi1, param, (uint16_t)param_size / 2);
                /* NOTE: CS will be reset in the transfer ready callback */
	lv_obj_t *obj;
	/* set screen background to white */
	lv_obj_t *scr = lv_screen_active();
	lv_obj_set_style_bg_color(scr, lv_color_white(), 0);
	lv_obj_set_style_bg_opa(scr, LV_OPA_100, 0);
	/* create label */
	obj = lv_label_create(scr);
	lv_obj_set_align(obj, LV_ALIGN_CENTER);
	lv_obj_set_height(obj, LV_SIZE_CONTENT);
	lv_obj_set_width(obj, LV_SIZE_CONTENT);
	lv_obj_set_style_text_font(obj, &lv_font_montserrat_14, 0);
	lv_obj_set_style_text_color(obj, lv_color_black(), 0);
	lv_label_set_text(obj, "Hello World!");
	if (lcd_io_init() != 0) {
	    printf("LCD initialization failed\n");
	    return;
	/* Create the LVGL display object and the LCD display driver */
	lcd_disp = lv_st7789_create(LCD_H_RES, LCD_V_RES, LV_LCD_FLAG_NONE, lcd_send_cmd, lcd_send_color);
	if (!lcd_disp) {
	    printf("Failed to create display driver\n");
	lv_display_set_rotation(lcd_disp, LV_DISPLAY_ROTATION_270);
	/* Allocate draw buffers on the heap. In this example we use two partial buffers of 1/10th size of the screen */
	lv_color_t * buf1 = NULL;
	lv_color_t * buf2 = NULL;
	uint32_t buf_size = LCD_H_RES * LCD_V_RES / 10 * lv_color_format_get_size(lv_display_get_color_format(lcd_disp));
	buf1 = lv_malloc(buf_size);
	if(buf1 == NULL) {
		LV_LOG_ERROR("display draw buffer malloc failed");
		return;
	buf2 = lv_malloc(buf_size);
	if(buf2 == NULL) {
		LV_LOG_ERROR("display buffer malloc failed");
		lv_free(buf1);
		return;
	lv_display_set_buffers(lcd_disp, buf1, buf2, buf_size, LV_DISPLAY_RENDER_MODE_PARTIAL);
	ui_init(lcd_disp);
	for(;;)
		/* The task running lv_timer_handler should have lower priority than that running `lv_tick_inc` */
		printf("Before lv_timer_handler\n");
		osDelay(10);
		lv_timer_handler();
		printf("After lv_timer_handler\n");
		osDelay(10);
	for(;;)
		HAL_GPIO_TogglePin(BLINK_GPIO_Port, BLINK_Pin); // Toggle the LED
		printf("Blinking\n");
		osDelay(250); // Delay in milliseconds
/* USER CODE END 4 */
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM17 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @param  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  /* USER CODE BEGIN Callback 0 */
  /* USER CODE END Callback 0 */
  if (htim->Instance == TIM17) {
    HAL_IncTick();
  /* USER CODE BEGIN Callback 1 */
  /* USER CODE END Callback 1 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
