I want to display different icons based on the current weather that is gotten from the OpenMeteo API.
I have tried to use cases and if the case is one of those, it uses the icon. Ex: case 0: // Clear sky
return is_day ? &sunny : &clear_night;
However, it does not ever display the icon. I have made sure the icons display by making example code to put the icon on the screen, and they show up, however, it wont show up in my UI. In my serial monitor I have an error that says: lv_draw_buf_init: Data size too small, required: 20000, provided: 1200 lv_draw_buf.c:281, however, I don’t know if this is related to icons.
/* if(img_weather) {
const lv_img_dsc_t* new_img = get_weather_image(wcode, is_day);
lv_img_set_src(img_weather, new_img);
// Ensure icon remains visible after update
lv_obj_clear_flag(img_weather, LV_OBJ_FLAG_HIDDEN);
const char *desc = "Unknown";
switch(wcode) {
case 0: desc = "Clear sky"; break;
case 1: desc = "Mainly clear"; break;
case 2: desc = "Partly cloudy"; break;
case 3: case 4: desc = "Overcast"; break;
case 45: case 48: desc = "Fog"; break;
case 51: case 53: case 55: desc = "Drizzle"; break;
case 56: case 57: desc = "Freezing drizzle"; break;
case 61: case 63: case 65: desc = "Rain"; break;
case 66: case 67: desc = "Freezing rain"; break;
case 71: case 73: case 75: case 77: desc = "Snow"; break;
case 80: case 81: case 82: desc = "Rain showers"; break;
case 85: case 86: case 87: case 88: case 89: case 90: desc = "Snow showers"; break;
case 95: case 96: case 97: case 98: case 99: desc = "Thunderstorm"; break;
default: desc = "Cloudy"; break;
}. as well as const lv_img_dsc_t* get_weather_image(int code, int is_day) {
switch(code) {
// Clear conditions
case 1: // Mainly clear
return is_day ? &mostly_sunny : &mostly_clear_night;
case 2: // Partly cloudy
return is_day ? &partly_cloudy : &partly_cloudy_night;
case 3: // Overcast
case 4: // Obscured sky
return &cloudy;
// Fog/mist/haze
case 45: // Fog
case 48: // Depositing rime fog
return &haze_fog_dust_smoke;
// Drizzle
case 51: // Light drizzle
case 53: // Moderate drizzle
case 55: // Dense drizzle
case 56: // Light freezing drizzle
case 57: // Dense freezing drizzle
return &drizzle;
// Rain
case 61: // Slight rain
case 63: // Moderate rain
case 66: // Light freezing rain
return &showers_rain;
case 65: // Heavy rain
case 67: // Heavy freezing rain
case 82: // Violent rain showers
return &heavy_rain;
// Rain showers
case 80: // Slight rain showers
case 81: // Moderate rain showers
return is_day ? &scattered_showers_day : &scattered_showers_night;
// Snow
case 71: // Slight snow fall
case 73: // Moderate snow fall
case 75: // Heavy snow fall
case 77: // Snow grains
case 85: // Slight snow showers
return &snow_showers_snow;
case 86: // Heavy snow showers
return &heavy_snow;
// Thunderstorms
case 95: // Thunderstorm
case 96: // Thunderstorm with slight hail
case 99: // Thunderstorm with heavy hail
return is_day ? &isolated_scattered_tstorms_day : &isolated_scattered_tstorms_night;
// Default cases
default:
// Handle unknown codes
if (is_day) {
if (code > 80) return &heavy_rain;
if (code > 70) return &snow_showers_snow;
return &partly_cloudy;
} else {
return &partly_cloudy_night;
- MCU/MPU/Board: ESP32 CYD.
- LVGL version: See
lv_version.h9.3.0
