I cannot get lvgl 9.2.2 to compile on a ESP32-S3.
Waveshare ESP32-S3-Touch-LCD-7 (800*480)
VScode / Platformio / Arduino
9.2.2
Use LVGL on this board.
This is my platformio.ini:
[env:esp32dev]
platform = espressif32@6.4.0
board = esp32-s3-devkitc-1
framework = arduino
monitor_speed = 115200
board_build.arduino.memory_type = qio_opi
board_build.flash_mode = qio
board_upload.flash_size = 8MB
board_upload.maximum_size = 8388608
board_build.extra_flags = -DBOARD_HAS_PSRAM
lib_deps = lvgl/lvgl @ 9.2.2
I do not even need to include lvgl in the main file, as soon as it is there as libdep, it doesn’t compile.
Therefore the main file is just a “Hullo Wurld” to Serial.
If i comment lvgl from libdeps, it compiles.
It compiles normally until:
Compiling .pio\build\esp32dev\liba12\lvgl\draw\sw\lv_draw_sw_fill.c.o
Compiling .pio\build\esp32dev\liba12\lvgl\draw\sw\lv_draw_sw_gradient.c.o
then comes a yellow line:
...\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\machine\_default_types.h: Assembler messages:
then a flood of errors saying all the same (different file names and line numbers):
...\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\machine\_default_types.h:41: Error: unknown opcode
or format name 'typedef'
LVGL 8.1
lvgl 8.1 throws a few warnings but it builds, only, I would really like to have 9.2.2, so I can reuse code from another project.
warning: assignment discards 'const' qualifier from pointer target type
Any hint?
Edit: Sorry, was in How-to category, but I think it’s gotta be here.
