As a novice, I have two questions to ask:
1.Can multiple parameters be carried in the event callback function?
For example, in the figure,label,btn can they be used as parameters in the function?
2.Can the gauge be changed to the following figure?
lvgl version: 8.3.0
Thank’s.
First of all in next time use [code] (```) block to post source code.
For answer to your first question need more information event_handler_q5_1() assigned to which object?
Second. As I know, the gauge can be only round or arc.
Thank you very much for your reply,
First question: I want to add the event callback function to a button, but there is no place to add parameters when adding it.Can I add some parameters, such as static void event_handler_q1(lv_event_t * e,lv_obj_t *label_2,lv_obj_t *slider1)
static void event_handler_q1(lv_event_t * e)
i_1=++i_1;
LV_LOG_USER("i_1: %d\n", i_1);
char buf[15];
lv_snprintf(buf,sizeof(buf),"%s / %s",*(arr+i_1),"1/30");
lv_label_set_text(label_2,buf);
if(0<=(i_1*(100/10))&&(i_1*(100/10))<40)
lv_slider_set_value(slider1,(i_1*(100/10)),0);
}else if(40<=(i_1*(100/10))&&(i_1*(100/10))<60)
lv_slider_set_value(slider1,40,0);
lv_arc_set_value(arc2, (i_1*(100/10)));
}else if(60<=(i_1*(100/10))&&(i_1*(100/10))<=100)
lv_arc_set_value(arc2, 60);
lv_slider_set_value(slider2,(60+(100-(i_1*(100/10)))),0);
lv_obj_add_event_cb(btn_1,event_handler_q1,LV_EVENT_ALL,NULL);
The second question: I want to know whether there is an official widgets that can achieve this effect by changing its style, except for the combination of widgets?
If you planning to work with only CLICK event, then assign handler to only CLICK event:
lv_obj_add_event_cb(btn_1, event_handler_q1, LV_EVENT_CLICKED, NULL);
this will reduce cpu load.
Next. label_2 is inside this button? Then you can get handle of this label by request childs of button:
lv_obj_t *btn = lv_event_get_target(e);
lv_obj_t *lbl = lv_obj_get_child(btn, 0);
lv_label_set_text(lbl, .... );
Slider you can pass as param to event:
lv_obj_add_event_cb(btn_1, event_handler_q1, LV_EVENT_CLICKED, slider1);
end then get this param from event:
lv_obj_t *slider = lv_event_get_user_data(e);
or you can allocate static array of ojects and pass it as param to event:
static lv_obj_t ctrls[2] = { label_2, slider_1 };
lv_obj_add_event_cb(btn_1, event_handler_q1, LV_EVENT_CLICKED, ctrls);
lv_obj_t *ctrls = lv_event_get_user_data(e);
lv_obj_t *label = ctrls[0];
lv_obj_t *slider = ctrls[1];
What? What kind of effect do you want?
Thank you very much for your answer
This widgets is composed of two sliders, two labels, two arcs, and a button. I wonder if there is a simpler way to implement it?
Looking forward to your reply.@spider_vc
I also have a question, can this param pass different types of parameters at the same time?
i_1=++i_1;
char buf[15];
such as int i_1 and lv_obj_t *slider1 and char arr[2][2]?
lihuihuang:
I don’t understand what must be in result. Can you draw different states?
you can pass pointer to any data. C Pointers
I drew some different states
Wow. I think the best way is make you own widget and process DRAW events…
Thank you very much
Another small question, is there a function that can delete all event functions of a widgets? If multiple event functions are added to a widgets, it is a bit troublesome to delete one by one. I can’t find them in the official documents
I don’t know any other ways.
You can bind only one handler for group of events and then remove only this handler.
