Hello!
I am using LVGL in a project that involves the Wii U gamepad. My project is going to be a custom boot menu/loader for the gamepad.
The gamepad itself is a fairly simple platform: ARM9 @ 108MHz, 4MB of RAM, simple LCD controller and DMA blit.
I was going to design the UI part of this project, and have been shown LVGL. I thought, hey, this is going to do what I want. So I grabbed the last release, 9.2.2, and integrated it into my project. So far, all good.
However, I have one concern.
The Wii U gamepad supports 4 display modes: 8-bit paletted, 4-bit paletted, ARGB1555 and RGB565.
For now, I have set up LVGL to use RGB565, and it works fine. However, it’s not ideal. The LCD resolution on the gamepad is 854x480, which means that a 16-bit framebuffer takes up about 800KB of memory, so almost 1/4th of the available memory. Not ideal.
You guess why the gamepad’s stock firmware uses the 8-bit paletted mode instead.
I’d like to use that mode, however, I’ve looked into LVGL’s inner workings and it doesn’t appear very straightforward. LVGL seems to use 24-bit colors internally, and when LV_COLOR_DEPTH is 8, they are converted to a luminance value intended for a greyscale display.
Easiest solution would be to use it like that, and fill the palette with a colored gradient, but that limits my UI to one shade of color.
Alternately, I would need to make a custom theme that uses color indexes instead of raw colors, but even then, I would still need to modify some of LVGL’s internals. For one, I’d need it to use the color indexes as-is instead of trying to calculate a luminance value from them. I’d also need to think of something for color blending and all.
Is there something more obvious that I’m missing? Is there a more straightforward way to make LVGL work with a paletted display mode?
