Can I set a lv_img_set_src using a uint8_t array?
I am using Zephyr and a PineTime DK (nRF52832) and trying to set and image from an array using lv_img_set_src, but I am doing something wrong as my app is crashing.
nRF52832 - PineTime DK - Zephyr - GNU GCC
8.3
Have an array of pixels show in an image widget.
Read this documentation which states I can call lv_img_set_src(img, src) which will take “a variable in code (a C array with the pixels).” I have tried to
uint8_t img_src[2049];
lv_obj_t *screen_image;
void screen_init() {
	screen_image = lv_img_create(lv_scr_act());
	lv_obj_align(screen_image, LV_ALIGN_CENTER, 0, 0);
	lv_obj_set_width(screen_image, 32);
	lv_obj_set_height(screen_image, 32);
void screen_img_set_src() {
	lv_img_set_src(screen_image, &img_src);
	lv_task_handler();
But I did notice when generating a file using the online conversion tool, that the result includes a structure. Does that mean a uint8_t img_src[] can’t be used?
const lv_img_dsc_t A32 = {
  .header.cf = LV_IMG_CF_TRUE_COLOR,
  .header.always_zero = 0,
  .header.reserved = 0,
  .header.w = 32,
  .header.h = 32,
  .data_size = 1024 * LV_COLOR_SIZE / 8,
  .data = A32_map,
I know it could be the content of my array, but wanted to make sure it was possible because I think I have the array being populated correctly.
Hi @lj001, see if this Images documentation will help you.
Thank you. That worked.
