I have two menu bars that are created from a rectangle object for the styling of the menu bar and it is the parent of the buttons that are added to it. The buttons function as menu items.
I created two menu bars this way with the same code (it is a menu class). The first menu works ok, the second doesn’t: the buttons are hidden by its menu_bar rectangle. Why is this because it obviously is the parent.
Maybe relevant: the menu system uses a my_top_layer_obj that covers the complete screen which is created using my_top_layer_obj = lv_obj_create(lv_layer_top()); So, everything happens above the top_layer, so to speak.
Any help is appreciated because it seems such a simple thing that should always work. I’m probably overlooking something.
I’m running under Windows simulator using SDL2
Latest
I want to create a menu bar with buttons and be able to style the buttons and the bar
Make the buttons a parent and put them on top using the standard lvgl functions like lv_obj_move_foreground() or lv_obj_set_parent(obj, new_parent(). But it doesn’t matter.
// Menu items are buttons, stored in an array
// an rectangle object ('my_menu_bar') is used to style a menu bar
// The buttons are its children
// The problem is: the first created menu bar works ok. The second created menu bar doesn't work:
// the menu buttons are not on top of its menu_bar_object. So, you can't see them or click them
// I used some opacy to make them visisble to show that they are there
// I added lv_obj_add_flag(my_top_layer_obj, LV_OBJ_FLAG_CLICKABLE); as a work around:
// I can click the buttons but they are still only visible by the use of opacy of the menu_bar obj
// Important to note : my_top_layer_obj is created before using :
// Create top layer. Everything canvas, views and docks is below this layer. The GUI (dialogs, menu bars and knobs, etc) are above.
lv_obj_clear_flag(my_top_layer_obj, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_set_scrollbar_mode(my_top_layer_obj, LV_SCROLLBAR_MODE_OFF);
lv_obj_add_style(my_top_layer_obj, &style_base_obj, LV_STATE_DEFAULT | LV_PART_MAIN);
lv_obj_set_pos(my_top_layer_obj, 0, 0);
lv_obj_set_size(my_top_layer_obj, MY_DISP_HOR_RES, MY_DISP_VER_RES);
lv_obj_add_event_cb(my_top_layer_obj, cb_top_layer, LV_EVENT_CLICKED, NULL);
// Then, I run this code (summarized)
// It creates a menu bar
constructor of menu class:
SoftKeyMenu::direction = direction;
// Constructor
for (int32_t i = 0; i < GUI_MAX_SOFT_KEYS; i++) {
btnArray[i] = nullptr;
// Create a rectangle object that is used to style a menu bar
// All menu items are children of this menu bar object
my_menu_bar = lv_obj_create(my_top_layer_obj);
lv_obj_add_style(my_menu_bar, &style_menu_bar, LV_STATE_DEFAULT | LV_PART_MAIN);
lv_obj_clear_flag(my_menu_bar, LV_OBJ_FLAG_CLICKABLE);
posx = 0; posy = 0;
width = 50; height = 100;
lv_obj_set_pos(my_menu_bar, posx, posy);
lv_obj_set_size(my_menu_bar, width, height);
destructor code of menu class
lv_obj_delete(my_menu_bar);
// AddButton function
AddButton(int32_t btn_index, lv_event_cb_t cb)
btnArray[btn_index] = lv_button_create(my_menu_bar);
lv_obj_add_style(btnArray[btn_index], &style_soft_key_v, LV_STATE_DEFAULT | LV_PART_MAIN);
lv_obj_set_pos(btnArray[btn_index], posx + 10, posy + button_position * 70);
lv_obj_remove_flag(btnArray[btn_index], LV_OBJ_FLAG_PRESS_LOCK);
lv_obj_add_event_cb(btnArray[btn_index], cb, LV_EVENT_CLICKED, NULL);
label = lv_label_create(btnArray[btn_index]);
lv_label_set_text(label, line1);
lv_obj_center(label);
ShowButton(btnArray[btn_index], false); // equivalent to: lv_obj_add_flag(btn, LV_OBJ_FLAG_HIDDEN);
return btnArray[btn_index];
// The code uses this for the menu bar style
lv_style_init(&style_menu_bar);
lv_style_set_border_color(&style_menu_bar, lv_color_make(0x00, 0x00, 0x00));
lv_style_set_border_width(&style_menu_bar, 0);
lv_style_set_radius(&style_menu_bar, 2);
lv_style_set_bg_color(&style_menu_bar, lv_color_make(0x55, 0x55, 0x55));
lv_style_set_bg_opa(&style_menu_bar, LV_OPA_50);
lv_style_set_pad_left(&style_menu_bar, 0);
lv_style_set_pad_right(&style_menu_bar, 0);
lv_style_set_pad_top(&style_menu_bar, 0);
lv_style_set_pad_bottom(&style_menu_bar, 0);
Two screen shots: one which works (white buttons) and one that doesn’t (with blue buttons)
