I am trying to figure out the best way to implement a button that you can slide up/down from to change a value. Something like a transparent slider that can only be “initiated” from the a button (?). The slide area could be across a whole screen
IMXRT1052
A button that can be slid up/down to change a value
I tried a normal slider, but that is active across it’s entire range and can’t have other buttons “underneath” it.
So then why don’t you use roller object. I think it’s exactly what you need. If your value is on another label you can change it in the callback of roller by catching the appropriate event.
Sort of. It would be like a slider where the bar is invisible and the bar moves instead of the knob.
This type of value slider is very common in UI for things like software synthesizers, where the user “grabs” a ui element like a knob or field and then moves across the whole screen to change the value. This saves space, instead of having a full slider where the knob moves over a bar.
ok, I started to mess around with the roller object. Here is an example, just using styles to change the look.
I would like to eliminate the “roll” visual behaviour, but I couldn’t find the code where it actually draws this during the scroll (?) The number should just change, not move up/down.
Turning animation off didn’t get rid of the rolling.
It is also a bit wasteful to store numeric values as strings for the options, preferably I could just define a top and bottom value numerically.
Then you are probably looking for the spinbox widget. The roller is designed to be used with strings, not just numbers.
As far as I know, the roller is implemented with a tall label that is moved as you scroll. What we would need here is a way to snap it to certain points rather than having it follow the cursor.
I think starting with an invisible slider with a label drawn on top of it is simpler than any of the other solutions.
OK, the spinbox widget is close to what I need. Here is an attempt.
I’m still not sure which signal can be used to capture dragging outside of the object sized area, like the roller does. I am using the signal “LV_SIGNAL_PRESSING” Also the label area of the text area for the spinbox doesn’t throw the same signal. So if I click on the actual label, the event isn’t triggered.
Here is my code snippet for the spinbox event:
else if (sign == LV_SIGNAL_PRESSING) {
lv_point_t p;
lv_coord_t h = lv_obj_get_height(spinbox);
lv_indev_get_point(param, &p);
int16_t tmp = 0;
p.y -= spinbox->coords.y1; /*Modify the point to shift with half knob (important on the start and end)*/
tmp = (int32_t) ((int32_t) p.y * (ext->range_max - ext->range_min + 1)) / (h);
tmp = ext->range_max - tmp; /*Invert the value: smaller value means higher y*/
if (tmp < ext->range_min)
tmp = ext->range_min;
else if (tmp > ext->range_max)
tmp = ext->range_max;
if (tmp > ext->drag_value) {
ext->drag_value = tmp;
lv_spinbox_increment(spinbox);
} else if (tmp < ext->drag_value) {
lv_spinbox_decrement(spinbox);
