I noticed that my button matrix buttons were not getting the correct size recently.
The bottom row height seems to be too big.
I have been testing this in the simulator sdl eclipse project.
What do you experience?
The bottom row buttons are being drawn too tall and row positions are slightly wrong.
What do you expect?
If you set the spacing of the btnm widget so that it divides the widget size exactly then all the rows should have the same height.
With the following code example you should end up with 6 rows of buttons which are 73 pixels high each.
//6 rows +
//5 inner spaces +
//top space +
//bottom space
6*73 + 5*8 + 1 + 1 = 480
But you end up with the bottom row being 78 high. This also means that all but the first row start at the incorrect height.
static lv_style_t style_btnm;
lv_style_copy(&style_btnm, &lv_style_plain_color);
style_btnm.body.padding.top = 1;
style_btnm.body.padding.bottom = 1;
style_btnm.body.padding.left = 1;
style_btnm.body.padding.right = 1;
style_btnm.body.padding.inner = 8;
static const char * btn_map[] = {
"1", "2", "\n",
"3", "4", "\n",
"5", "6", "\n",
"7", "8", "\n",
"9", "n", "\n",
"0", "y", ""
lv_obj_t* pinpad = lv_btnm_create(lv_disp_get_scr_act(NULL), NULL);
lv_btnm_set_style(pinpad, LV_BTNM_STYLE_BG, &style_btnm);
lv_btnm_set_map(pinpad, btn_map);
lv_obj_set_size(pinpad, 320, 480);
I put an overlay of the bottom row button in to make the size difference more obvious.
Solution
I looked into it and found what seems like a slight miscalculation to me on line 244 of lv_btnm.c
act_y += btn_h + style_bg->body.padding.inner;
I think this should be adding another 1 to act_y each row because the btn_h is 1 smaller than the actual button height.
