I’m using a button matrix to create a scrollable (matrix height is set larger than screen resolution height) menu on one of my screens. I’ve set the control of all buttons in the button matrix to have LV_VALUE_CHANGED on CLICK instead of pressed, yet when I scroll through my menu my buttons are still being triggered.
I’m using a LPCxpresso54628 Development Board.
Version 8.0.2
The buttons in my menu to not be triggered when scrolling through the menu, only when clicked.
Using the provided function “lv_btnmatrix_set_btn_ctrl_all(my_matrix, LV_BTNMATRIX_CTRL_CLICK_TRIG | LV_BTNMATRIX_CTRL_NO_REPEAT)”
Below is a link to the micropython simulator using lvgl version 8.1, I reproduced the problem but with a simple numberpad. You can see that if you scroll around on the numberpad and then release (on a key) it’ll still trigger the event to add what key was press into the textarea.
https://sim.lvgl.io/v8.1/micropython/ports/javascript/index.html?script_direct=4ffd88de0342cfdd2ab8b5602ddb564e68dec0a5
For those that don’t like links, here’s the code from the micropython simulator:
# Initialize
import display_driver
import lvgl as lv
# Create a button matrix as a numberpad
scr = lv.obj()
matrix_cont = lv.obj(scr)
matrix_cont.set_size(200, 320)
matrix_cont.set_pos(220, 0)
# Text area for testing
text = lv.textarea(scr)
text.set_size(220, 320)
# Styling for the textarea
text_style = lv.style_t()
text_style.init()
text_style.set_radius(0)
text_style.set_border_width(0)
text_style.set_text_color(lv.color_make(0x00, 0x00, 0x00))
text.add_style(text_style, 0)
# The numberpad button matrix
matrix_map = [
"1","2","3"," ","\n",
"4","5","6"," ","\n",
"7","8","9"," ","\n",
"<-","0",".","-",""]
matrix = lv.btnmatrix(matrix_cont)
matrix.set_size(200, 400)
matrix.set_pos(0,0)
matrix.set_map(matrix_map)
matrix.set_btn_ctrl(3, lv.btnmatrix.CTRL.HIDDEN)
matrix.set_btn_ctrl(7, lv.btnmatrix.CTRL.HIDDEN)
matrix.set_btn_ctrl(11, lv.btnmatrix.CTRL.HIDDEN)
# Styling for the button matrix
matrix_style = lv.style_t()
matrix_style.init()
matrix_style.set_radius(0)
matrix_style.set_bg_color(lv.color_make(0x40, 0x65, 0xFF))
matrix_style.set_border_width(0)
matrix_style.set_pad_left(0)
matrix_style.set_pad_right(0)
matrix_style.set_pad_top(0)
matrix_style.set_pad_bottom(0)
matrix_style.set_pad_row(0)
matrix_style.set_pad_column(0)
# Styling for the button matrix buttons
matrix_button_style = lv.style_t()
matrix_button_style.init()
matrix_button_style.set_radius(0)
matrix_button_style.set_bg_color(lv.color_make(0x40, 0x65, 0xFF))
matrix_button_style.set_border_width(1)
matrix_button_style.set_border_color(lv.color_make(0xFF, 0xFF, 0xFF))
matrix_button_style.set_text_color(lv.color_make(0xFF, 0xFF, 0xFF))
matrix.add_style(matrix_style, 0)
matrix.add_style(matrix_button_style, lv.PART.ITEMS)
# Comment out this line below to see how the event handler would process the numberpad
# Using lv.EVENT.VALUE_CHANGED on pressed instead of on clicked
matrix.set_btn_ctrl_all(lv.btnmatrix.CTRL.CLICK_TRIG|lv.btnmatrix.CTRL.NO_REPEAT)
# From documentation, LV_EVENT_CLICKED: Called on release if an object did not
# scroll (regardless of long press)
def event_handler(e):
code = e.get_code()
obj = e.get_target()
if code == lv.EVENT.VALUE_CHANGED:
btn_id = obj.get_selected_btn()
text.add_text(obj.get_btn_text(btn_id))
matrix.add_event_cb(event_handler, lv.EVENT.ALL, None)
lv.scr_load(scr)
