When using a button matrix, is it possible to have the buttons fit tightly around their contents?
The screenshot below shows a button matrix with “C:” and “M:” labels. These buttons expanded to fill the width of the parent container, and expanded in height to make the button a square. I would liket o make these buttons a similar size to the “x” and “^” buttons.
The button matrix has some styling applied to remove the margin and padding.
Windows x64, MSVC.
7.9.1
Make the buttons in the button matrix fit tightly.
I attempted to use lv_cont_set_fit(btn_drvmtrx, LV_FIT_TIGHT); but that’s not compatible with the button matrix object.
Code
Full code at https://github.com/deltabeard/haiyajan-lvgl/blob/master/src/main.c
What I currently use to create the button matrix:
lv_obj_t *btn_drvmtrx = lv_btnmatrix_create(cont, NULL);
lv_btnmatrix_set_map(btn_drvmtrx, btn_drvs_ptr);
lv_btnmatrix_set_one_check(btn_drvmtrx, true);
lv_btnmatrix_set_btn_ctrl_all(btn_drvmtrx, LV_BTNMATRIX_CTRL_CHECKABLE);
lv_obj_set_style_local_pad_all(btn_drvmtrx, LV_BTNMATRIX_PART_BG, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_margin_all(btn_drvmtrx, LV_BTNMATRIX_PART_BG, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_pad_all(btn_drvmtrx, LV_BTNMATRIX_PART_BTN, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_margin_all(btn_drvmtrx, LV_BTNMATRIX_PART_BTN, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_border_width(btn_drvmtrx, LV_BTNMATRIX_PART_BG, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_outline_width(btn_drvmtrx, LV_BTNMATRIX_PART_BG, LV_STATE_DEFAULT, 0);
Many thanks.
sorry didn’t see it,you already do this
