I am trying to find a way to click button matrix button’s only one time. I need no effect, no animation and no state change for second click to same button on button matrixs (btnm). I have written my code then realized to check tab view transition for how tab view transition but they(my call back and tabview transition ) are similar for translation.
There is another-way to set toggle press/button press styles same and toggle release/button release styles same but i do not want to change buttons native natures. So how can i do it to click only ones on same button on button matrix.
STM32F7 series
How can i do it to click only ones on same button on button matrix.
/*declarations are all above functions*/
static void btnm1_event_handler(lv_obj_t * obj, lv_event_t event)
// this part from tabview change
if(event != LV_EVENT_CLICKED) return;
uint16_t btn_id = lv_btnm_get_active_btn(obj);
if(btn_id == LV_BTNM_BTN_NONE) return;
lv_btnm_clear_btn_ctrl_all(obj, LV_BTNM_CTRL_TGL_STATE);
lv_btnm_set_btn_ctrl_all(obj, LV_BTNM_CTRL_TGL_ENABLE);
lv_btnm_set_one_toggle(obj, true);
lv_btnm_set_btn_ctrl(obj, btn_id, LV_BTNM_CTRL_TGL_STATE);
lv_btnm_clear_btn_ctrl(obj, btn_id, LV_BTNM_CTRL_TGL_ENABLE);
//this is my own code. both are working similar
//printf("%d was pressed\n", event);
lv_btnm_set_btn_ctrl_all(obj,LV_BTNM_CTRL_NO_REPEAT);
if(event == LV_EVENT_RELEASED) {
//printf("btn id: %d \n", btn_id);
lv_btnm_set_btn_ctrl(obj,btn_id,LV_BTNM_CTRL_TGL_STATE);
simulator4buttonmatrix-2019-08-20_08.38.zip (2.6 MB)
This trick should work:
static uint16_t btn_first = LV_BTNM_BTN_NONE;
uint16_t id = lv_btnm_get_active_btn(obj);
lv_btnm_ext_t * ext = lv_obj_get_ext_attr(obj);
if(event == LV_EVENT_PRESSED) {
if(id != btn_first) { /*A new button or first click because `btn_first == LV_BTNM_BTN_NONE`*/
ext->btn_id_pr = LV_BTNM_BTN_NONE;
ext->btn_id_act = LV_BTNM_BTN_NONE;
btn_first = id;
else {
printf("Second click\n");
} else if(event == LV_EVENT_PRESSING) {
if(id == btn_first) { /*If still pressing the same button ignore it*/
I have check your codes but not worked for me.
It kind of does something else before click/pressed or pressing to change state.
I need to keep same state and visual when same button is clicked/pressed until different button is clicked/pressed.
Please check my short screen cast.
buttonmatrix-2019-08-21_10.29.zip (3.9 MB)
thanks
I also have tried to find out from btnm values for what effect make changes it’s state so print all btnm values on any events. I am not sure but it seems like something change before event happens.
buttonmatrix2-2019-08-21_11.06.zip (3.9 MB)
I don’t understand exactly what you mean, but are you looking to toggle the buttons and only allow one of them to be toggled at once? If so, you could try the “one toggle” feature:
https://docs.littlevgl.com/en/html/object-types/btnm.html#one-toggle
Be sure to have toggling enabled on all the relevant buttons (LV_BTNM_CTRL_TGL_ENABLE). It will ensure that when you toggle the next button the previous one is toggled back to the original unpressed state.
I need no changes(keep its states, and also no visual effects) When I pressed toggled button.
So you want to disable the ability to untoggle a button?
yes, until different btnm button is pressed.
I misunderstood your goal. How about this one?
static uint16_t prev_tgl_id = LV_BTNM_BTN_NONE;
if(event == LV_EVENT_VALUE_CHANGED) {
/*Untoggle previous*/
lv_btnm_clear_btn_ctrl(obj, prev_tgl_id, LV_BTNM_CTRL_TGL_STATE);
/*Be sure the current is toggled*/
lv_btnm_set_btn_ctrl(obj, id, LV_BTNM_CTRL_TGL_STATE);
prev_tgl_id = id;
Thanks. It works.
I have to mention one thing. If you have any toggled button on initial state, you have to clear all toggle states. So I just replace
lv_btnm_clear_btn_ctrl -> lv_btnm_clear_btn_ctrl_all
//lv_btnm_clear_btn_ctrl(obj, prev_tgl_id, LV_BTNM_CTRL_TGL_STATE);
lv_btnm_clear_btn_ctrl_all(obj,LV_BTNM_CTRL_TGL_STATE);
prev_tgl_id = id;
It works well, thanks again.
hello, i’m beginner, i’m working on the same topic but with LVGL 8.1 and i want to uncheck the pressed last button if i press a second time,
I need to have just one button checked and have the possibility to uncheck all buttons (as they are at first view of screen,
lv_btnmatrix_set_btn_ctrl_all(btnm1 , LV_BTNMATRIX_CTRL_CHECKABLE);
lv_btnmatrix_set_one_checked(btnm1, true);
first view (all buttons are unchecked)
here all time i have one button activated, i think it’s due to : ##lv_btnmatrix_set_one_checked()
is there a solution to uncheck all after ?
It should work
lv_obj_t * obj = lv_btnmatrix_create(lv_scr_act());
lv_btnmatrix_set_btn_ctrl_all(obj, LV_BTNMATRIX_CTRL_CHECKABLE);
lv_btnmatrix_set_one_checked(obj, true);
/*Make a button checked manually*/
lv_btnmatrix_set_btn_ctrl(obj, 3, LV_BTNMATRIX_CTRL_CHECKED);
/*Uncheck all buttons*/
lv_btnmatrix_clear_btn_ctrl_all(obj, LV_BTNMATRIX_CTRL_CHECKED);
Hi @kisvegabor,
My issue is that i can’t know the state of my button (checked or not) all i get is focused and pressed
Could you have a look to my post here ? I hope you will understand my issue
Hi @Zebra067 ,
I have replied here. If you want to give that a try?
Cheers,
Pete
