Button is Checked 0/1 value
Hello all, (version 8.4) I’ve spent about an hour going through the documentation but can’t figure out this:
Is there a way to check the status of a button if it is checked? (not the actual event of it being checked)
Ideally I want to be able to multiply a value by a button status to only give the value during the time when the button is checked.
So kind of:
(lv_button_checked * value)
so that when the lv_button_checked is 1, the value of the calculation is “value”
cheers, Giles
I’ve not tried this myself but I figure checking the state of the button might work.
See: Objects — LVGL documentation
And: Base object (lv_obj) — LVGL documentation
Something like this:
if (lv_obj_has_state(btn, LV_STATE_CHECKED) == true)
   /* something */
Yep that works perfectly - thank you @Tinus !! I’d not quite connected that Checked was a State and that I could use has_state in that way. Nice one.
